Discuss How do i wire up this new light? in the DIY Electrical Advice area at ElectriciansForums.net
How do i rewire up this new light? Unsure were to rewire in the block.puctures beliw
To make the installation of your new light easier, I would suggest getting an Electrician in, probably an hours work including travel locally, it will save you a lot of heartache, if you try it yourself, you could get into a right mess, the Electrician will do the work safely. Not taking the easy option, I have seen many people get into all sorts of trouble trying to do, what to an Electrician, is a simple job.
As above. If you really want to do it yourself, you first need to learn how the UK loop-in lighting wiring is done.
Once you map that onto what you have in your ceiling it should be a simple matter of wire substitution.
And lucky you, both of your new lights have a spare terminal for the live loop (that's the red wires in your ceiling box).
Who said electrics were easy.
which side of liverpool? can do for £45 -£65 all in, depending on distance travel.
Woof.Woof.
Reply to How do i wire up this new light? in the DIY Electrical Advice area at ElectriciansForums.net
