Discuss How do i wire up this new light? in the DIY Electrical Advice area at ElectriciansForums.net
How do i rewire up this new light? Unsure were to rewire in the block.puctures beliw
To make the installation of your new light easier, I would suggest getting an Electrician in, probably an hours work including travel locally, it will save you a lot of heartache, if you try it yourself, you could get into a right mess, the Electrician will do the work safely. Not taking the easy option, I have seen many people get into all sorts of trouble trying to do, what to an Electrician, is a simple job.
As above. If you really want to do it yourself, you first need to learn how the UK loop-in lighting wiring is done.
Once you map that onto what you have in your ceiling it should be a simple matter of wire substitution.
And lucky you, both of your new lights have a spare terminal for the live loop (that's the red wires in your ceiling box).
Who said electrics were easy.
which side of liverpool? can do for ÂŁ45 -ÂŁ65 all in, depending on distance travel.
Woof.Woof.
Reply to How do i wire up this new light? in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I have an outdoor light I am trying to hookup. There are two wires coming in with a white, black and ground. One is coming from the breaker and...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
Hi, there are 3 bundles of wires coming from my ceiling and I've been told they have been tested with a multimeter and have all got a current but...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
