Darkwood
Moving a socket 200mm to the left if you are a builder - how to join the cable in the wall before plastering it over.
To be fair, the actual joints had a bit of thin card to protect the joint from the plaster.
NB: The original cable is rubber, approx. 60 years old, and exposed basic insulation has become quite crumbly.
Never assume anything. Customer has 32A MCB tripping off a submain CU in their annex. They tell me it’s on the socket circuit. Switch the power on when I arrive and stood talking but back door. Loud pop coming from garden. Only circuit out there is to a double socket in greenhouse. Find loose termination and think job done. Power back on.. pop. Narrowed down to flower bed between house and greenhouse. Unprotected T&E coming away from house under raised path then into plastic duct! Say no more. Then waste an hour trying to locate spur off RFC so it can be isolated. Finally check CU and establish it’s on its own circuit ( no labels on old MEM board) and nothing to do with RFC running sockets in annex as told by customer. :rolleyes:
It's a lesson learned, always assume the customer is not the best source of info past the fact the breaker/rcd trips, saved many an hour in my life ignoring most of what they think themselves, it's how they answer your questions that matters.
I find it amazing the number of CU’s that have not circuit labels on them despite having nice stickers on the front to put the details on.
50045
?! Who knows. It’s a bit strange because it looks like someone has grabbed a 4mm earth from somewhere when they could have the CPC in the pvc/pvc. I don’t think it was for bonding.
All fixed now but what a mess. Almost wilfully poor.
8K
Darkwood,
mainline,
