Discuss Smart Meters that can be installed at the Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
Smart Meters that can be installed at the Consumer Unit.
For situations where a tenant wants the facility but the landlord doesn't want a a smart meter on their premises.
Does anyone know of such a device?
I'm thinking of something that can be installed outside of the CU monitoring the line inside the CU.
Between the main switch and, say, the RCDs or the busbar.
Cheers
No need for additional meters, the Tenant has the right to have a "Smart" Meter installed.
The meter does not belong to the Landlord.
The landlord owns the property. The property is private. If he/she doesn't want a smart meter it's up to them. That quote from Ofgem doesn't say otherwise. The word is "unreasonably". The electricity company doesn't get to define that. Nor does the government. As far as I'm aware.
Anyway, that said, are you aware of a device such as the one I described?
Do they need to be accurate MID approved meters for billing, or do they simply want to see more or less how much power they are using during a day?
I think there are plenty of power monitors that are good enough and have fancy app interfaces if it is for general use management.
Yes. For guidance really. In theory all you need is a continuous monitoring of the load on a time line.
The rest is software. You could use the same sort of induction technology that you find in a clamp meter.
So you just need a sensor that goes around the line in the CU with a battery operated wall mounted device
outside that reads the current and produces the data.
Do you have such a system in mind?
What about an energy monitor such as Owl etc.
Yes, there are many current transformer based monitors available, installed as you suggest. From cheap DIY things on Amazon to professional MID certified devices.
Here's an example:
The simpler 'DIY' devices tend to have a battery powered CT transmitter, that is simple to install, but will need batteries changing. I think the "proper" MID approved type need hard wiring (but still use a CT), so a competent installer required.
Here's an example:
Got it. Thanks
The landlord has absolutely no authority to prevent a smart meter from being installed
Reply to Smart Meters that can be installed at the Consumer Unit in the UK Electrical Forum area at ElectriciansForums.net
