Discuss Have the rules for ring mains changed over the years? in the Electrical Engineering Chat area at ElectriciansForums.net
Sure, what I actually had in mind was if there was only a 4 way rewireable Wylex there in the first place the space for a replacement can be limited (if of course the replacement occupies the same spot)
In a small house where the kitchen is the utility room, you might have a dishwasher, washing machine and tumble drier all on together for over an hour. Ironing the previous load while the next one is washing and drying. A cuppa, kippers on toast. It's not a given that a 20A circuit won't get a little warm!
I don't disagree that other designs work, and multiple radials is certainly possible, but it is a convenient and resilient circuit for variable loads.
Aside from their ability to 'just get on with' periods of heavy use, they are probably the circuit that it is easiest to prove is in an excellent condition and discover modifications via the extensive tests that are possible.
To clarify, I don't think anyone is saying that we can't possibly do without them. It's about whether there are benefits to choosing to use them.
I much prefer how they do it in France, their electrics are much nicer. Their CU's are nicer too, good old double storey jobby.
No because that is a stupid argument.
Europe not having rings despite their rules being made up by dozens of countries of expert bodies proves we don't need rings. End of story.
And our rules were also made by experts, experts who created what is widely regarded as the best designed and safest general use plug and socket system.
The ring circuit was developed due to a particular set of circumstances in this country and if they had occurred in other countries they would likely have adopted the ring circuit too.
I wouldn't be adding more circuits to a re wireable Cu.
Having all those appliances on one circuit is wrong anyway, whether it be a ring or radial.
Possible ? Radials are the most common circuit in use and installed.
So is a radial
Prove is a bit of a strong word ?
You can't prove any circuit is in excellent condition just using an MFT.
There are benefits to using a Ring final, there are also benefits using a horse and cart compared to a van.
In what way are the electrics nicer?
And what makes their CUs so much better?
Plastic quarter turn screws that become brittle and break, use of screwdriver reduced by 1/3, DP breakers that take up twice as much space and not much else, other than more money to be made if longer jobs are deemed better than getting finished and moving on to the next.
Apparently.
More room in the CU to work, wago'd earth bar, double pole breakers, no dreadful flat profile cable, more appliances on separate circuits giving better selectivity, main switch provided on incoming head as standard, pre-sleeved earth wires, pre-wired conduit, better selection of fittings (especially for lights), better light switch rocker size, no ring final's, better looking plugs, variable supply (bringing it down brings standing charge down), colour coded cable so you can see on sight what size it is....
Just obviously better than the horror show here in the UK.
Wait until you see how they slate roofs. Although i'm sure someone will try to say pinning with nails like we do is best.
Yeah but what makes them nicer lol.
As long as you choose the right CU then there's not much issue with ours.
wago'd earth bar,
Interesting, that sounds like a good idea, do you have an example of this?
Yes because they require them for safety on their single phase circuits, our single phase supplies/circuits are safe with DP MCB's. DP MCB's and DBs are available in the UK when they are required.
Whats wrong with flat profile cable?
I'm not sure how this affects selectivity?
Interesting, I'm aware of the need for an RCD/RCBO at the supply head due to their common earthing systems and restricted current supplies.
Supply isolators are becoming common here for small supplies and I agree that it's is a good thing that we should have been doing years ago.
Why does that matter?
pre-wired conduit
Whats that look like? Doesn't that defeat the object of having conduit in the first place?
Surely a pre-wired conduit is just a cable?
OK, but that's personal choice and I can't say I've ever had an issue with the available selection of light fittings in this country.
Is there a particular type of light fitting you feel is missing from this country?
If you want bigger switch rockers you can get them in this country.
This is really starting to sound like you are clutching at straws.
, no ring final's,
Why is that better? It's just a different way of doing things.
Really? That's such a subjective thing and really not important is it?
Why does the look of the plug matter?
Does it, or rather, would it?
I doubt standing charges would go down if you introduced that as the cost of altering so many supllies would be phenomenal.
I hadn't realised that idea had spread to mainland Europe, I thought it was only in the USA that domestic electricians needed colour coded cables to be able to identify their size!
Do you have any examples? Ive not studied electrical installations in mainland Europe but from what I have seen I thought most of their cable was plain white.
I really don't see how you can describe UK electrical installations as a horror show.
Reply to Have the rules for ring mains changed over the years? in the Electrical Engineering Chat area at ElectriciansForums.net
