Im aware it works with standard saws, jist wondering if anyone tried it, orlnows of, a way of it working with thoseIt works with standard holesaw
You thread the 50mm inside the bigger holesaw to widen the hole cleanly
Better to use a Starrett Oops arbor (CK do something similar tooIt works with standard holesaw
Better to use a Starrett Oops arbor (CK do something similar as well)
How does that work theres 2 different size threads
Usually when I'm widening the hole the holesaws are same thread
I'm not sure why you would intentionally drill a hole smaller than what you would need, but you would then use the bit you used as the pilot, and rather than having just a few mm as a lead you have as much as you want. Works on the larger and smaller arbors.I see there it men's starting off with a small hole
I'd normally be starting at about 50mm or the standard size for a basic GU10 and tho enables you to conform the cables are there
With you there, just for finding the cable?...unless they're redundant fitting holes which need enlarging for new.I'm not sure why you would intentionally drill a hole smaller than what you would need
When stripping down a motor gear box assembly (or for any assembly with multiple parts and casings) take a dot punch, lightly dot each item with its corresponding part, (taking care to not damage any engineered surfaces) especially if there are multiple possible positions but the original position is crucial on re-assembly.
I post this because one of my less experienced team members has just stripped a gearbox assembly down to replace some worn parts. He did have the common sense to mark the parts but used a "permanent" marker pen, only to wash the marks off at the de-greasing station.
Yeah, sure with modern technology we can take snap shots that can be very useful. However, in certain circumstances you are looking for 100% reliability, digital pictures can be accidently erased.Good post
Shooting from the hip but how much if any of that can you do with a camera phone
Prob not much
I got into the habit of taking out the phone and taking loads of pictures when strioping stuff down and reassembling
Electricians Tips from a professional electrician in the UK Electrical Forum
Sometimes you need to work in an old house, and there’s a number of threads on here about how to, say, fit downlights in a lathe ceiling.....
Here’s a start... on lathe and plaster walls without making a huge mess....
Mark where you want the socket to go. Height wise, measure an existing one from either the floor or the top of the skirting.
Next, use a pad saw to find a gap between the lathes. Hit and miss jabbing with the saw until it breaks through.
I will be using a regular dry lining box, so you don’t want to be too close to a vertical joist. Use the pad saw to feel to the left and right. If you can feel a joist, just adjust your planned position.
Once you have the final position, you can draw around a regular metal back box to give your cutout size.
Using a multi tool on a fairly slow speed, you can chip away at the plaster, but not the lathe quite yet.
yet.
Now, with the multi tool on a high speed and a fine toothed wood blade, you can cut neatly through the lathe without much problem. A small wood screw screwed into the middle of the lathe and held tight in pliers will help as the lathe will want to push into the hollow wall.
Now for the biggest tip I can give. Very very important whenever you are doing anything like this;
Always remember to charge your phone fully, or it will die when you’re in the middle of trying to make a hints and tips
And an extra 500 quid probably,and the rest with taping etcNo problem jock. It was an old thread until some spammers sent message after message and resurrected it.
It’s reminding me of a more recent job where I fitted 4 downlights in a perfect straight line on a lath ceiling, only for the customer to be convinced by her joiner that the ceiling needed strapped and boarded.
Then it became 4 downlights in a straight line AND perfectly matching with the holes above.
