K
killerking
Hi i have brought a floodlight from focus today to replace my existing light, it came without instructions (it was the last one the box was open), the problem is it always stays on, i have it running off a switched spur, inside the unit it has a 4 way connector block, i have live to live, earth to earth and netural to netural, but on the outgoing on the 4th connector there is a red wire going into the bulb or pir and a white wire doing the same, i have a photo i have attached, any help please
you seem to have wired it correctly. the 4th terminal with the red is to feed a slave flood, so don't use it. it may be stuck in manual mode so, to cure this, switch off and wait for 30 secs. switch on and it should come on for whatever the timer is set for, then go off. if not, it's probably faulty.
its a overide facility for always on so if you are having a barbeque or in the garden at night then switch the fcu off for 2 secs switch back on and it stays on
then to go back to pir mode do as stated above
yep they sure are MK products at clearance prices lololololol still £3.00 more than i pay now ,
bought some runner bean seads got 30p off bargin ,, wind slugs ate the last lot
yep they sure are MK products at clearance prices lololololol still £3.00 more than i pay now LOL - yeah i passes one today though i'd wait til they get the 90% off signs out- then you might actually be saving something!
Are they the flying rats?
I have a similar problem with a security light but the swithcing off then on again thing doesn't work, I assume the photocell or similar is knackered, checked the wiring and that is all OK and there is nothing in the manual about manual switching.
Floodlight with PIR constantly on
Australia
killerking,
down2earth,
