Currently reading:
Immersion Heater - PV electricity
Discuss Immersion Heater - PV electricity in the Central Heating Systems area at ElectriciansForums.net
Hi echase,
Having read the last 20 pages or so of this thread I am intersetd to learn more about your controller system. I have no particular wish to reinvent, nor do I have the specialist knowledge to do so, but could put together from kit or go ready built. Please provide further info on options and prices. I can't find a direct link to your e-mail address.
thanks
Mo
Message for EChase - yes me too - I have a customer who is particularly interested in a system to supplement a PV system we fitted recently. Could you send me some details
As for the flash rate, every time it records a flash, the power dumped into the immersion heater will reduce, I can live with a long period between flashes as this represents a consumption of just 1Wh.
I'll get back with my results in a moth or sos time and crow or eat humble-pie as appropriate.
I like the approach Sparqui, and would be interested to know how you have been getting on since this posting.
Also would appreciate hearing from echase as to availability of his system or designs therefor (am capable of building most things from circuit diagrams).
TIA
How much, and does it have a mains filter? Oh, and can it cope with the PV being on the same consumer unit as the rest of the house, i.e no way to measure house current directly without threading several wires through the current transformer?
OK then, what's the price? You're stating publicly that it's "good" so it's only right that you tell us what it is. The point about a filter is important: things like EMMA may be overpriced and overspecified for this application, but they comply with regulations regarding the electromagnetic interference they generate, a problem which may not be obvious to users of alternative systems and which has caused misunderstandings on this thread (e.g. a snubber network is not the same as an EMI filter).
Sorry if this has been answered before, has anyone found a true power sensor at a reasonable price? I want to measure the actual power exported to the grid and use this to control a Crydom controller (as others have done). Hopefully this approach will be more accurate than deriving the small difference between two comparatively large currents, and also maybe cheaper.
If there isn't a commercial solution for <£100 then I will try a current transformer/Hall effect current sensor and feed the output of this together with a stepped down version of the supply voltage into an Analog Devices analogue multiplier.
This when averaged should give me true rms power (with sign!) which I can then use to drive the Crydom unit, and also a panel meter giving me an instantaneous import/export display.
Anyone out there tried any or all of this and can recommend components etc for it?
TIA
You would be wise to read the openenergymonitor.org forums about this. People have spent a lot of time on it, and found gotchas like phase shifts in transformers for measuring voltage causing inaccuracies in the calculation of true power.
...I find it quite remarkable that folks are prepared to buy and fit unknown electrical devices to their home from strangers, and know so little about them...
Have tried, but it repeatedly and consistently crashes my browser (plain vanilla IE7).
Am alive to that one, may well use a resistive or capacitative voltage divider instead. Have made another little device which uses a capacitor dropper in the power supply too, for low dissipation. Not too worried about using mains neutral as the 0V DC rail, it's all going in a steel box anyway.
The CT I propose to use (Magnatec SCT 0400-050) has 1% linearity from 5 to 65A and a max phase errror of 2 deg, do you think that is suffiently precise?
I do not plan to be too greedy, it will be fine if 90% of the output goes into the immersion heater and I end up exporting 10%, this will give me simple proportional control with no appreciable lag and no long-term drift.
Download a better browser - there are far more important reasons for it than being able to read those forums.
I was actually talking about the voltage transformer. I do recommend you do make the effort to look at those forums because it may save you a lot of wheel-reinventing. I would probably build something like you're proposing as I don't have the PV on a separate CU so can't measure house current directly. That is, unless I went down the digital route. But as the saving is so small (of the order of £50 a year if you're on mains gas?) I've shelved the project for the time being.
Just a quick comment I checked my gas consumption over a month with no heating and I reckon I will save about £150 per year. I guess I need the kids to get out of the shower a bit quicker :)
Reply to Immersion Heater - PV electricity in the Central Heating Systems area at ElectriciansForums.net
