I
ibby
I put my postcode into good earth, and i found my house.
But which way is North and South?
Easiest way would be to make the North East wall a gable end, (same as you are planning to do to the Sout West wall) however you're going to get some shading from those new dormers![]()
I'd expect that would be next doors roof you're discussing, but could be wrong.Easiest way would be to make the North East wall a gable end, (same as you are planning to do to the Sout West wall) however you're going to get some shading from those new dormers![]()
ibby - I really don't see that you're going to have space for a solar system with that layout. Could you not drop at least one of the dormas and put a window in the gable wall instead?
Unless you are at home during the day you won't offset the bill much, do an ROI calc based on investment cost and savings and then you can make a proper judgement.
If you have drawings done for the roof conversion, then a number of people on the forum here should be able to give you a good ball park figure for your system, also some of them have 3d software so they can model your new roof for shading and give you a pretty accurate answer.
Just because PV is the latest things, doesn't always mean it the right thing - you might also want to look at combination panels that do both PV and Hot water in one panel.
more cost effective to just do a small grid connect system plus UPS for the servers / computers if you want a secure power supply.I was looking at PV, to off set my electric bill.
Maybe I should look at a smaller off grid system to power my computers and servers.
