Currently reading:
150m Cable run outside to spur?
Discuss 150m Cable run outside to spur? in the DIY Electrical Advice area at ElectriciansForums.net
lol wow, just wow. I give up. do you even read the previous posts?
This will be done by my electrician who is well in depth, I was just interested in the cable size so i could price it up.
Like I said forget it, Ill have a ring round.
And where exactly did you say that you had an electrician carrying out the work ??
Also your electrician will get differnt prices from his wholesaler which you will unlikely be able to beat due to the fact he gets trade prices so ringing round getting prices is pointless and surely you spark has quoted you a price for the work so why worry ???
Read INPUT current rating on label on power supply. Multiply by 3. Post answer. This info was needed at post #1.
It is not a simple question at all though, there are many variables to take into account, not just electrical ones but environmental ones too.
sheesh
I read every one of your replies and asked questions accordingly, you were unable to answer what I asked so in return wouldn't have been able to answer your question with out the required information
You obviously don't have a proper understanding of electrical principles. These questions are asked for a reason not to slip you up. There is a DIY forum for this sort of reason, which would also explain some of the replies you recieved originally.
Since when do I have to tell you I have a spark to carry out the work?
I wont be ringing round Ill be ringing Neweys and putting it on my account, I literally just wanted a size.
Ive had 2 quotes with different cable sizes hence the question, any other things you need to know?
Sorry Conner but you have posted in the general forum and this should be in the DIY section ... posting in here will give members an assumption you are competent to some extent unless you tell us otherwise.... as you haven't this has led to the barage of unhelpful replies... although it late and some members may not have anything better to do than slate it is clear you are not competent in relation to your question and i would have thought rather than kick you while your down some members could have suggested your in the wrong section.... You have my apologies for the lack of help...
At which end is the 12 volt needed?
At the end of the 150 meter run? Or will the cable be carrying 12 for 150 meters?
What type of cable are you looking at using?
This....Really
You wanted to know cable size, which is determined by load current. By post 35, you still haven't told us what that is, although we can now at least guess
lol oh right so its the wrong section, thats the reason for all the smart arse comments, i get it.
Right well if thats what I need to do Ill get it. thats was easy
Yes, there was reason why that section was opened. This thread is one of them.
I'm just a trainee so don't listen to me, I guess the following is more aimed at the experienced and qualified folks:
If the largest voltage drop I can find in appendix 4 of the OSG is 44mV/A/m (1mm^2), then the largest voltage drop is going to be 6.6V/A over 150m. Assuming these 3 transformers are not wildly inefficient, they're going to be drawing less than an amp at 230V... so even if they're not switch mode PSUs they're probably still going to be ok.
So (aside from environmental protection and other stuff I've not thought of and have yet to learn about), what's up with doing a rough calculation as above and saying, "the smallest SWA you can get"?
Volts drop has different allowances for specific load types although at such low load it may not effect cable size we need to know the load characteristics not just the load rating ...i ask a few times as you haven't responded with an answer we cannot really give assistance... the distance is excessive so for our help you need to answer what we ask ... if it was several meters we could give an educated guess ... the supply has to meet ZS requirements so trip times are met under fault again not to difficult with short runs but 150m is a bit of a run... i have 3 pubs within 150m of my house by comparison.
Knew there was summat. Zs. Sorry. ~embarrassed~
Ok so ill get the relevant info when on site tomorrow.
HappySteve, thanks for the info, Dilb take note.
Nah, don't thank me, and I'll reiterate don't listen to me. Just learning, and as DW states above I made a rooky error because I forgot summat basic.
To be honest, I'm more with Dillb on this...
Rough calculation can be taken as gospel if advised on a forum you go to help from.. we don't do rough as it can in certain cases risk life... we are advising people with no electrical background sometimes and if we suggest it may need a competent person to look at the set-up its usually because we cannot attain the correct info or we believe the Poster is at risk themselves tying to do something with limited knowledge.
But what about the spark who you was getting to do the job? Wont he be able to tell you tomorrow?
Point taken.
We have been trying to help, you choose to ignore us as we wont commit until we have ALL the relevant information.
Sorry if you choose to ignore this but really, you are putting alot at risk by asking for a rough guess.
Dilib and DW were trying to help you, only you don't know enough about what it is you were asking.
Reply to 150m Cable run outside to spur? in the DIY Electrical Advice area at ElectriciansForums.net
