C
Connor2425
What would be the required cable for this type of run?
Discuss 150m Cable run outside to spur? in the DIY Electrical Advice area at ElectriciansForums.net
lol wow, just wow. I give up. do you even read the previous posts?
This will be done by my electrician who is well in depth, I was just interested in the cable size so i could price it up.
Like I said forget it, Ill have a ring round.
At which end is the 12 volt needed?
At the end of the 150 meter run? Or will the cable be carrying 12 for 150 meters?
What type of cable are you looking at using?
Sorry Conner but you have posted in the general forum and this should be in the DIY section ... posting in here will give members an assumption you are competent to some extent unless you tell us otherwise.... as you haven't this has led to the barage of unhelpful replies... although it late and some members may not have anything better to do than slate it is clear you are not competent in relation to your question and i would have thought rather than kick you while your down some members could have suggested your in the wrong section.... You have my apologies for the lack of help...
You wanted to know cable size, which is determined by load current. By post 35, you still haven't told us what that is, although we can now at least guess
Right well if thats what I need to do Ill get it. thats was easy
Now, what are the power ratings of the transformers at 230 volt?
About half an hour too late
Volts drop has different allowances for specific load types although at such low load it may not effect cable size we need to know the load characteristics not just the load rating ...i ask a few times as you haven't responded with an answer we cannot really give assistance... the distance is excessive so for our help you need to answer what we ask ... if it was several meters we could give an educated guess ... the supply has to meet ZS requirements so trip times are met under fault again not to difficult with short runs but 150m is a bit of a run... i have 3 pubs within 150m of my house by comparison.
Nah, don't thank me, and I'll reiterate don't listen to me. Just learning, and as DW states above I made a rooky error because I forgot summat basic.HappySteve, thanks for the info, Dilb take note.
Reply to 150m Cable run outside to spur? in the DIY Electrical Advice area at ElectriciansForums.net
