Discuss Installing a Floodlight in the DIY Electrical Advice area at ElectriciansForums.net
I need to install a floodlight for outside now its dark. Its just inside the kitchen wall to connect to the electrics. My simple idea is run a cable through a wall with a plug on the end and use a sensor LED light - is that allowed or am I breaking any rules?
An electricial has said tap into ceiling light, run trunking around the kitchen wall and ceilings, put in a fused spur which really seems a lot of work - I guess its the proper way but its ugly and very expensive.
Any feedback please on what option to go for?
It is fine what you are proposing.
Reactions: DPG
Reply to Installing a Floodlight in the DIY Electrical Advice area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Hi all, I have a single switch in my garage to turn on a couple of lights in there. Yesterday I fitted a floodlight outside, drilled through...
I have had three led strips installed under wall units as part of a kitchen refit. A new pattress box was fitted in a stud wall next to an...
Hello I’m going to install a hard wired 230v security camera, incorporating floodlights, outside and above garage door onto brick. An exposed...
Hi all We are hoping to upgrade our oven. We currently have a single integrated oven and a separate induction hob. Each has its own red switch...
