Currently reading:
a strange question
Discuss a strange question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
lofty84
When the emf in a conductor 0.15m long moving at right angles through a magnetic field, at a velocity of 2 m/s is 0.5 V, the magnetic flux density would be
Thanks to the guys in the general electricains forum I know know that the formula is
B = e / l x v
so 0.5 / 0.15 x 2
= 1.66 T
the problem is that I have been told the the answer is 3.17 T
is there something else that I need to do to the original formula ?
thankyou IQ
could I trouble you with this one
24. If a three phase, four pole, 50Hz induction motor has a slip of 4%, the actual speed of the motor would be
a. 1240 rpm
b. 1550 rpm
c. 1440 rpm --> CORRECT ANSWER
d. 1000 rpm
I cant seem to work it out tho
thankyou IQ
a. 1240 rpm
b. 1550 rpm
d. 1000 rpm
think i might have worked it out
ok
50/ 2 = 25 rps
25 rps x 60 = 1500
1500 / 100 = 15
15 x 96 = 1440 prm
No problem, don't forget the 'thanks' button though, it shows members your appreciation ;)
Any others, just post them up, it's good practice for all of us!
one more ?
a circuit with a capacitor of capacitive reactance 5 ohms an induction of 8 ohms inductive reactance and a resistor of 4 ohms conected in series to a 230v 50hz supply what would the total impedance be
a 5 ohms
b 10 ohms
c 3 ohms
d 6 hms
is it 2 x pie x f x l
a capacitor of 25 (funny U) F is connected i series with a resistor in circuit with with a 50hz 200v a.c supply. determine the capacitive resistance.
I know the formula is XC = 1 / 2 x pie x f x l
but i cant get the answer which is 127 ohms
can anyone help
one more ?
a 5 ohms
b 10 ohms
c 3 ohms
d 6 hms
Z = square root of R^2 + X^2
X = Xl - Xc
X = 3
Z = square root of 16 + 9
Z = 5 Ohms
Where there is capacitive reactance and inductive reactance, the value of X is always the larger value minus the smaller which in this case is 8-5 = 3
an a.c load has an output power of 12 kw and an input of 15 kva. determine the reactive power
can anyone work this out it looks simple but i cant remember what to do again
Heres a weird one
what are the copper losses in the primary winding of a step up tansformer, where the resistance of the winding is 0.3 ohm and the transformer is drawing 8 amps from the supply ?
any Ideas IQ ?
ive got more
what is the current that can be drawn from a 100va transformer if it has an out put voltage of 20 v
another is
if a transformer has a maximum output voltage of 200v and supplies a current of 12a what is the KVA rateing of the transformer
P=VI
KVA translates into Kilo volt amperes
KVA is apparent power, and Kw is real power.
So to work out apparent power, you multiply the real power by thepower factor. As you haven't given me a power factor, i asuume unity ( a power factor of 1).
So in other words, KW and KVA are one and the same, with a power factor of one.
some more if thats ok and youve got time
a single phase transformer with 2000 primary turns and 700 secondary turns is fed from a 230v ac supply determine the secondary voltage
a transformer haveing a turns ratio of 2.8 (primary to secondary) is connected to a 230 v supply. calculate the output voltage
= 700/2000 x 230 = 0.85 v is that right
= = 8/2 x 230 = 920 v is this right
When a current of 200mA flows into a capacitor for 40mS, the charge developed in the capacitor would be ???
I dont suppose anyone knows the answer for this
Reply to a strange question in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
