My G4 system is presently fitted with an LED remote keypad. My wife does not find this user friendly so I have purchased a LCD remote keypad.
I have asked the original installer to do the replacement for me without success. I know he is employed on new-builds which take up most of his time.
I am a retired radar engineer so I think this job should be within my capabilities. I have the Operating Instructions, and the Engineers Manual but before I attempt the job I would like to ask if there is anything I should be aware of.
There is a key-operated switch alongside the main panel and a fuse immediately below the panel. Would I be correct in thinking that if I switch the key switch to the off position, remove the fuse and then remove the battery from inside the main panel no alarm will subsequently sound. I'm assuming the bell-box gets it's power from the control panel.
Is it then a case of taking the wires one-by-one from the LED RKP and fitting them in the new LCD RKP?
If by any chance the alarm should sound I should be able to cancel it by my user code. My biggest concern relates to the engineers access code. I do not know if the installer changed this from the default. Do I need to be concerned.
I will be most grateful for any advice you are able to impart.
Many thanks
Ken
Many thanks
Ken
