Currently reading:
Bend pvc conduit
Discuss Bend pvc conduit in the UK Electrical Forum area at ElectriciansForums.net
How would you guys to bend pvc conduit 20mm&25mm with spring to create 3 saddle bend or four saddle bend? Not like a simple 90 degree bends. Is there any formula or tricks or any steps you guys would do? Because I used the app to calculate the distance to bend but end up too close each bend and impossible with my knee. I think the app I use if for bend EMT with bender. So any recommendations? Thanks
youse can warm itby vigorous rubbing with a cloth. friction makes heatso warms the conduit. don't use your lady's knickers. might get a static shock as well as a punch in the mouth.
So I’m assuming best way to make 4 saddle bend without any extra tools would be draw a template on the ground and try to bend? I’ve practised but only problem is the bends are more than 45 degrees. Because I can’t force much with my arms.
I was on a job recently and the original sparks had used pre made pvc conduit offsets...
Not sure on the cost but surprised we don't see more of them this day and age.
I like a bit of conduit myself. Uses the brain and something different.
As for the Americans. They also like ready. Made formers/presses... Put your conduit in(Steel) pull lever and outcomes a formed offset bend etc depending on the former inside.
Reply to Bend pvc conduit in the UK Electrical Forum area at ElectriciansForums.net
