Hi everyone found this today cooker outlet converted to a double socket which the cooker is plugged into it then a extension lead plugged into other socket which runs the gas hob ignition and garden sockets and garden light's all on 33amp mcb with 6mm from board to cooker then 1.5mm to outside socket then 2.5mm armoured cable split into two to run sockets and lighting any thoughts on this
Yes, where did they get the 33Amp CB and where did they stable their horses whilst doing the wiring, and how do they sleep at night?
Not a great set up. This should be split up and done properly. Please get an electrician to check it
Are the SWA radials hard wired into this double socket or are they coming of the extension?
As far as I see it nothing wrong with the set up. A bit weird agree, but ok.
Only the SWA would be a concern if it's hard wired.
I can't honestly see any issue on the face of it. The fixed wiring is one double socket protected by a 32a mcb with 6mm cable. No issue there at all unless the cable is 200m long.
Then there are two things plugged in, outside the scope of fixed wiring, and although dodgy sounds, the latter setup must be protected by a max 13A fuse. The load doesn't sound like it would overload the fuse, garden lighting and a socket, no kettles involved. Or heaters. Although someone might plug in some ir patio heaters perhaps.
So it all depends on the workmanship really.
United Kingdom
United Kingdom
Business Name
M.c.electrics
Cooker outlet plate converted to double socket
markco,
johnduffell,
