H
harrison2987
Anyone with experience of this or an idea please help.
I have 2 phases going going into a cab, each one 230v. However there is a real chance someone could touch the two and get a belt from each phase at the same time.
What would be the correct type of warning sign to use? Also out of interest, if they did get a belt off the two would they recieve a 460v shock?!
Thanks in advance guys!!!! : )
Re: Correct warning signs for high voltage (potential belt off 2 phases) please help!
NO, ... 400V!! This isn't high voltage either but standard Low voltage. Any standard warning notice that brings to the attention the presence of 400 volts being present will suffice...
Thanks for the help
400v is all well and good, just remember those dreaded amps..!
Non as it as this cropped up in work and on checking the regs whilst it was in the 16th edition (514-10) it has now been removed from the 17th edition so non is required.
Is it really regarded as good practice not to warn others of impending voltages within cabinets ?
I think, if the switch room cabinet, or whatever it is, is not under the direct supervision of skilled personnel with suitable locks and warnings in place then there maybe a case of a lack of duty of care, particularly, if someone was then to receive a shock because they were stupid enough to stick their fingers in there.....
i`d be putting a warning label on the enclosure advising that theres 400V (nominal) available between phases...
Label as if a numpty was working in there. Not sure on your setup but if each enclosure has 230v then label them with 230v. We then normally add a 400v between label. Yes it's overkill but it covers your arse and works.
nail, head, hit
Expected voltage in electrical enclosures is 230v where you exceed this then a 400v warning should e affixed, also when you say cab what do you mean? ... Electrical enclosure? How exactly would someone come into contact with both phases (i assume they are over different phases... your opening post has me questioning myself)... if they require a tool or key etc to gain access then they should be competent to be working on 3ph if they can gain access without a tool then an overview of the safety of the set-up will be needed to address this.
As a voltage exceeding 230V to Earth (Uo) does not exist, no warning is required.
I refer you to 514.10.1 ........ there is no mention potential measured to earth, if you have item or equipment with a NOMINAL voltage exceeding 230v where it would normally not be expected then before access can be gained a clear warning label should be visible
Correct warning signs for high voltage (potential belt off 2 phases) please help!!!
harrison2987,
Engineer54,
