- Reaction score
- 10,616
Hopefully will re qualify next year. Colleagues & friends are already thinking of using me to do some work for them then, which is good! I've had my nose buried in the various books, however I'm getting confused over the positioning of replacement CU's.
A friend wants his CU replaced, but it is currently in a cupboard above his kitchen wall units.
Building regs Part P, states the CU (or other switches) should be installed above the flood plain, not installed where young children may interfere with them, but recommends installed above 450mm - below 1200mm, for accessibility by disabled persons (M document). RCD/RCBO's should be readily accessible.
However, it goes on to say M doc' applies to new builds and there is no requirement in rewires, providing it is left in no worse terms of level of compliance.
Am I right in thinking that my fiends CU can stay where it currently is? If it can’t, then circuits/tails would need extending, which would be a common issue for most CU's
My neighbour has had a CU changed. The original was in a cupboard next to the kitchen. The cupboard was knocked through into the new kitchen, and the CU moved up the wall next to the ceiling (i.e. above 1200mm),so that goes against M doc’ recommendations?
Is there reference to this in BS7671?
