- Reaction score
- 86
Discuss EICR What would you do? in the UK Electrical Forum area at ElectriciansForums.net
Damien,
Come on, you are totally missing the point.
The DB is a TTA.
You have no idea of the performance with another manufacturers breaker.
But surely one concern is the arc resulting from a fault and whether it causes any damage.It's not down to the cables, it is ONLY to do with the protective devices, end of.
well let's just all stay in bed all day then, it's clearly not safe to venture out. What the hells the point of BS standards then? What a load of none sense. There is no way a different manufacturers MCB in a domestic CU is a C2, it's jus ya blinking MCB for gods sake. No wonder the country's going down the pan.......Oh I have spoken to & debated with Schneider at length, and the answer I had at the time was NO to a Chint breaker, now they may have changed their tune, that is their prerogative.
However without that information, we cannot make that decision.
I have several contacts at Schneider, and not just through the technical support line.
This is all to do with type testing and partial type testing, to ensure safety of the final assemblies no more.
The only "person" who can ensure the safety is the person that manufactures it and type tests it, now if it is modified from the original type testing, then it is down to the "person" doing the modifications to ensure it still meets the type testing requirements7.
What sodding issue is there going to be with a fooking MCB for Christi's sake?????? Is the CU going to explode???? What EXACTLY is going to go wrong??????Oh I am in the real world.
Temporarily perhaps, but, you would find that in the event of an issue, any and all liability would fall directly on you as the designer, and installer of the product.
Why is this so hard to comprehend?
Almost all of you on here hold 7671 as a standard that should be adhered to, why do you find it so hard to comply with other relevant standards?
Do you ignore 5266 or 5839?
Yes or no?
IF no, then why do you ignore other comparable standards?
Is it because you know nothing about them, or is it because you just choose to ignore them because it suits you?
Baldsparkies, it seems your quoting has gone a bit awry tonight, it's normally mine.
The MCB does not on it's own have Type Approval, to comply with Annexe ZA of BS EN 60439-3 the whole board MUST be type approved, so that includes the bus bar, the main switch, the enclosure, the internal wiring supplied by the manufacturer etc.
Like it or not that is the situation.
It is the board that is a Type Tested Assembly, or Partially Type Tested Assembly, hence the term assembly.
This is the issue, you are invalidating the type testing of the assembly, and of story, no matter what anyone says, if you modify the board, then you are invalidating the manufactures type testing, like it or not you are.
Thus you are taking on the role of manufacturer, thus you must ensure that the modified unit meets the requirements for placing on the market.
Thus, you must undertake the full suite of tests to verify that this is so, to ensure that your new product complies with the product standard which you are manufacturing to.
As I have just said there is an alternative and that is to meet the requirements of BS 6423.
It's up to you, you can comply with the statute law by either method, however unless you undertake one or the other you will not comply with the statute law, end of.
Your right I have gone a bit off track and of course the entire board has to comply throughout.
Sorry for not making that clear I didn't mean to say otherwise although my last post would imply so.
I do know exactly where your coming from but I will stand by the use of plain old common sense in these situations.
If the MCB is from a reputable supplier suitably type tested and fits the existing connection points in the same way as the original then I would deem it safe for use, with a C3 on a EICR.
If your car needed a new set of brake pads would you always fit OEM parts or have you ever fitted good quality after market at half the price.
Of course you have and not lost sleep over it either.
And thats the brakes on a vehicle that could be carrying your family, let alone an mcb from a different manufacturer.
it's an MCB. It sits in a DIN rail (another standard?) with a bit of cable fixed into the top/bottom and a connection to a bus bar in the bottom/top, all with screws that any old driver will turn. They all have defined ratings, how complicated can it be? What would you do then, in the scenario I mentioned??? You wouldn't last 2 mins in the workday of domestic sparking.Have you looked into the potential failure modes of the devices?
Do you understand fully the potential failure modes of the devices and how they interact with the assembly into which they are fitted?
60898 does not take this into account, it is not required to.
However, it is somewhat irrelevant.
I will ask again why are you willing to say defend the requirements of 7671 yet ignore equivalent requirements in other standards?
This is not a pick 'n' mix in Woolworths for Christmas sweets.
A mixed device could allow a catastrophic failure within the board.
The detail of the interaction between the "foreign" device and the rest of the assembly can only be ascertained by testing, so if this testing is not done, how would you know what the issues could be?
The point is it is a totally unknown scenario, and it totally untested to check whether it is safe or not.
Have you EVER seen an MCB fail catastrophically due to excessive SSC or FC?
Ahh, now there in is an issue, brake parts for cars now must by law be manufactured to OEM specs, where as MCB's don't have to meet the requirements for the assembly into which you fit them!
hey if you worried less you might still have a full head of hair, loosen up mateThe MCB's dont have to meet the requirements for the assembly they fit into, ????????????????
Like I said this is really getting sillier and sillier.
BS/EN 60898 type B 6amp with a 6k rating replaced with a BS/EN 60898 type B 6amp with a 6k rating.
Thats it really, let common sense prevail here pleeeeese.
Im off to bed and hope no body gets nuked by a bloody chint breaker in a merlin board.
Interesting thread though, be boring if we all agreed lads, and sparkies are buggers for disagreeing lol x
no code at all.
C2 is a ridiculous suggestion.
Two seemingly valid interpretations of the legislation from experienced electricians.
As a learner I find this very useful; it prompts me to read the regs and carry out more research on this topic Genuine thanks to all the contributors. :smile5:
With the vast majority of commonly available domestic MCBs there seems to only be one or two factories producing them with the only difference between brands being the screen printing on the front of them.
You can easily put together a CU from different brands but the exact same manufacturer, what code would you give that?
I would like to know how 'putting it in the marketplace' is defined, as to common sense that suggests it is going to be something along the lines of 'being offered for sale'
But in this thread it is being used with reference to equipment being installed in private properties?
Blimey this has rumbled on and on! I am only fitting all RCBO boards from now on haha!!
Reply to EICR What would you do? in the UK Electrical Forum area at ElectriciansForums.net
