hello there
have a possible job lined up to fit 4 elv(12v) downlights in a smallish room, now the room is not classed as a special location so as i understand it a pelv or selv circuit could be used. i have not previously fitted elv downlights so not really sure about whats available or what i would need.
1/ i see that there are pre wired selv transformers, and non pre wired transformers. Am i correct in thinking that the non pre wired can be con figured for a pelv circuit?
2/ for a pelv circuit do the actual downlight fittings have to be double insulated?therefore different to selv fittings
3/ is the supply side of the transormer (selv) earthed? as the seperation is provided by the double insulation between primary/secondary. fully aware that the ELV side has no direct connection to earth.
4/ which configuration is used for non special locations pelv or selv circuits
i know some of these questions are basic just never worked on elv up until now, any advice much appreciated.
