Currently reading:
Help.. no lights downstairs in my home
Discuss Help.. no lights downstairs in my home in the UK Electrical Forum area at ElectriciansForums.net
jrt
Hope someone can please help with strange (to me) issue
I turned lights in last night in my home & they came on & then went off. But all apart from 1 light downstairs in my house doesn't work. At first I thought fuse, but it's ok. The 1 light that stays on is on same fuse as the ones that won't. None are linked with same switch so none of the lounge, kitchen, dining room, hall or lower toilet are working. Any ideas on where to start to remedy ?
A spark will soon suss out whether you've lost the feed or the neutral to those lights that are not working. The loss of either has to be either a break at a connection at a three terminal ceiling rose, or behind a switch or in an octopus joint box below the floor.
Think he has bodged the repair himself Les, only saying cos I'm out.
New posts
Reply to Help.. no lights downstairs in my home in the UK Electrical Forum area at ElectriciansForums.net
