I'm looking for advice on what you think would be the best cost effective solution. I intend to pay an electrician to do all connections but would like to have in mind the best solution before I bring them in. The cealing is plasterboard and the wall is blocks for switch 1 and switch A, plasterboard for Switch 2. I would like to do the least amount of wall/ceiling repair. I'm willing to use smart switch solutions if cost effective.
The goal is to split the daisy chain so I can switch on/of lights 6 & 7 (which are above my dining table) separately from 1,2,3,4,5,8,9 & 10.
Apologies for my English and non-electrician terms in advance!
I have 10 4.4W LED Collingwood H2 Lite downlights (1 - 10 in the drawing) connected as a daisychain using Scolmore Flow CT101C connectors to a switch (wall switch 1) there's also a two way switch (wall switch 2). There's also 3 separate downlights of the same type nearby with a switch (A, B, C and Wall Switch A in the drawing).
I was thinking to change the order in which the daisy chain is connected so lights 1,6,7 are the first lights in the daisy chain (in that order), and the rest go from 7 to 8 (with a smart switch like Sonoff R2 between them) to control the lights connected 8, 5, 4, 3, 2 & 8,9,10. That way I can switch on 1,6,7 (albeit I just need 6 & 7 - I can live with 1 being on) from the wall and set the Sonoff to stay off the the switch goes on. I can the switch the rest of the lights from the app whn needed as they are not used very frequently.
An alternative similar solution would be to chain the daisy chain order in so lights 6 & 7 are connected to A, B C and maybe put a Sonoff R2 between C & 7.
I'm looking to read all your suggestions and pro-cons to try to come-up with the easiest, safest, most cost effective solution.
Besides the drawing above I attached photos of 2 of the 3 switches the light spec and connector.
Thank you for your comments.
- TL;DR
- Trying to workout the best way to split a 10 downlights daisy chain to control in 2 separate zones as opposed to all 10 at the same time.
