M
Max1882
Hi all, new to the forum so go easy!Ha......At work we have a pump with a 3 phase motor attached.....the wires that come from the winding are 50mm....The lid with the incoming flex has 70mm tails.....yes i know this is wrong but i was going to use 70mm through crimps and just crimp it a bit tighter on the side with the 50mm tails.......My problem is how can i insulate these crimps? 2/3/4 layers etc of heat shrink? Someone has mentioned self amalgamating tape? or can you get more heavy duty sleeving etc? BTW it'sa74kw motor pulling 140 amps....Any help welcome.....Thanks....
Max
Max
