Hi,
First post so go easy on me. Looking for some advice on kitchen appliances (washing machine, dishwasher and fridge/freezer) because I have to move some of them in a kitchen redesign happening soon.
At the moment, I have above bench fused switches for each appliance, then below bench sockets (no switch) on the wall, where the appliance actually plugs in. There is limited space available so I no longer want the sockets on the wall behind the appliance.
For 2 of the appliances, the above counter fused switch can stay in place but I want to move (extend slightly) the under bench socket from the wall, to a socket in a surface mounted backbox in an adjoining cupboard. This will still be easily accessible for isolation or emergencies. Am I ok to replace the current under bench wall socket with an outlet plate (e.g. 20A unswitched flex outlet plate) and run 2.5mm cable a short distance (1m ish) to the new socket in the surface mounted backbox?
For 1 of the appliances, the above counter fused switch will be covered during the redesign by a cupboard so becomes inaccessible without removing back of cupboard. The cupboards do have a recessed back to allow for surface wiring etc. For this, I was proposing to replace the above counter fused switch with an outlet plate and run 2.5mm cable the short distance to a nearby cupboard where the appliance would plug in (again, a socket in a surface mounted back box). I have 2 questions on this: i) should the new socket be fused or is the appliance plug fuse sufficient . ii) is my intended approach of leaving surface mounted wiring behind a cupboard acceptable?
If there are better solutions to achieve the above then please let me know and thanks in advance.
Firstly I would recommend employing an electrician to carry out any alterations or additions of this type.
Placing a socket outlet for an appliance in an adjacent cupboard, would be ok. You don’t need to have an above worktop ‘switch’, unless your complying with Part M, i.e. a new build.
If a socket outlet would be hidden by a cupboard, I would recommend relocating it, if possible. If not the faceplate should be removed, and suitable maintenance free connectors and blanking plate used. Somewhere documented, that the joint is located behind the cupboard.
I have done quite a few kitchen refurbishments, relocating or adding sockets etc. I often did it by removing/altering/rewiring rather than covering them up. Often the work was done by removing part of the ceiling, if there was expensive flooring above. The plasterboard ceiling would be reinstated, skimmed & decorated.
As said, I would recommend employing an electrician.
If the space behind the appliances is just a few mm too short, fitting flush sockets might be a quicker/easier option. Recessed sockets exist, but you need more wall thickness than you will find in most houses to fit them!
Thanks for your replies. I'm a homeowner and not a tradesmen, hence trying to understand the nature of job before deciding how to continue.
In my experience @infaddict, quite often in a kitchen refurb' in an older property, you can spend some considerable time putting right what the previous owners/kitchen fitters have bodged.
Are you altering your lighting? The ceiling method, is the easiest way to approach things.
Newcastle
United Kingdom
Kitchen appliances & sockets, switches, isolation etc.
UK
infaddict,
Midwest,
