I
infaddict
Hi,
First post so go easy on me. Looking for some advice on kitchen appliances (washing machine, dishwasher and fridge/freezer) because I have to move some of them in a kitchen redesign happening soon.
At the moment, I have above bench fused switches for each appliance, then below bench sockets (no switch) on the wall, where the appliance actually plugs in. There is limited space available so I no longer want the sockets on the wall behind the appliance.
For 2 of the appliances, the above counter fused switch can stay in place but I want to move (extend slightly) the under bench socket from the wall, to a socket in a surface mounted backbox in an adjoining cupboard. This will still be easily accessible for isolation or emergencies. Am I ok to replace the current under bench wall socket with an outlet plate (e.g. 20A unswitched flex outlet plate) and run 2.5mm cable a short distance (1m ish) to the new socket in the surface mounted backbox?
For 1 of the appliances, the above counter fused switch will be covered during the redesign by a cupboard so becomes inaccessible without removing back of cupboard. The cupboards do have a recessed back to allow for surface wiring etc. For this, I was proposing to replace the above counter fused switch with an outlet plate and run 2.5mm cable the short distance to a nearby cupboard where the appliance would plug in (again, a socket in a surface mounted back box). I have 2 questions on this: i) should the new socket be fused or is the appliance plug fuse sufficient . ii) is my intended approach of leaving surface mounted wiring behind a cupboard acceptable?
If there are better solutions to achieve the above then please let me know and thanks in advance.
