Evening...Can anyone tell me which reg this breaks??
It feeds a switched fuse.
Drill a hole elsewhere on the busbar !!
But yes that is a busbar support with the bolt captive in the bakelite so you could never tighten it too much.
I agree but I would not like to make a judgement on a non recommended ad hoc connection that it does not pose a danger as you have nothing to gauge it against. It is difficult to see but the only way that lug can be fitting flat to the busbar is if it has broken the plastic busbar support which it looks like it has.
You could gauge it by the fact that it has almost certainly been there for a considerable time, (red cable), and seems not to have spontaneously combusted yet.
If the bolt just screws into the bakelite I'm not sure you could reliably torque it. So I'm back with the thought that it's a locating bolt, not a termination point so it will not be designed for this use.
Leeds
Live cable taken straight off busbar..Reg no. required.
dtec dave,
DPG,
