R
rm0210
Hi all.
Just wondered what other sparky's view on where main bonding is not in place when you look at a job(no matter how small)
ive been told buy my part p assessor that if the main bonding is not in place you should say to the customer that this needs to be done before any electrical work is carried out.if the customer refuses to get this done,you should walk away from the job.
Ive looked through the regs(as much as i can cope with!)and the osg and have found nothing to back this up in black and white.
In the past if the bonding is not in place or bieng hidden behind kitchen funiture for example i have made the customer aware of this and made a note on the test report(minor works)or issued a failed pir or eic for the work i have done because they have refused to get the bonding done.
What does everybody else do?
Walkaway?
Advise?
Allow it in quote and do if accepted?
i understand how important main bonding is especially pme systems but surely you cant keep walking off jobs beacuse it is not in place!
Walkaway?
Advise?
