- Reaction score
- 381
I would just knock the wall down and hang the cu on the back of the new door, no drama, 2 screws, easy.
Discuss Moving the CU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Move the cu extend circuits issue MW for each circuit.....................simples.............why the protracted debate?
A customer wants a consumer unit moved about a meter to one side, because she's converting the garage and wants to put a door where the consumer unit is now.
Good call,but surely hanging the CU on the door will require all circuits to have new flexible cables which,will require testing.Its a mine field....I would just knock the wall down and hang the cu on the back of the new door, no drama, 2 screws, easy.
but its not a cu change, it is relocating the same cu. Unless i read the post wrong which isnt unknown.
So how many when they extend a ringfinal issue an EIC? not me.
So if its the same cu just relocated (no change in ocpd's or rcd's) & the circuits require extending why would you complete an EIC?
Reply to Moving the CU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
