Currently reading:
Outhouse Consumer Unit and Underground Cable
Discuss Outhouse Consumer Unit and Underground Cable in the UK Electrical Forum area at ElectriciansForums.net
Kash
Hi,
I am currently having my whole house renovated and I am also having a new outhouse built (brick/block cavity wall etc..). We want to put a small kitchen in the outhouse and so will need to run Gas and Electric etc... We will also be putting the boiler and unvented cylinder in the outhouse.
I already know about the trench requirements etc... I would like to know about cable, consumer unit requirements.
I wont be doing any of the work my self and will be bringing a qualified electrician, but I like to know the best approach with these things, which why I am here.
I have read you can spur off the original house CU, as long as you use the side that is not connected to the RCD? Is that even the case when having a oven etc... ? I understand the CU in the house will have it's own RCD so that should cover it, just wanted confirmation?
Also in regards to cable its about 20m (max) from the outhouse to where the current house consumer unit (main fuse) is. What thickness armored cable would be recommend?
We will most likely have to upgrade the existing consumer unit as we are also building a extension and building a dormer and there aren't enough mcb's in the current unit, what would be the recommendation for the size of unit?
The house will be (after extending) 5 Bed, 2 Bath, 2 Reception, a WC, Kitchen then outhouse with another small kitchen (with the boiler and cylinder).
I hope I have provided enough information.
Appreciate any advice given.
So, who is doing this work?
Shouldn't you be talking to the electrician who will actually be doing the job?
So the builders has finally bought in a electrician to do the job as the trenches have just finished being dug out. The electrician will be doing all the work. I asked him about the setup as well and he basically gave me a few options and one of those was what I wrote above.
Hilarious stuff this. The OP should write sitcoms.
Not sure what is so funny. Just curious about how all this would work, the answers I was getting back on this forum was ask the electrician (who wasn't around at the time), so I thought I would ask here considering that's the point of this forum?
I am guessing people probably take it as free advice or think I might be crazy and do the install my self.
Anyway I am sorted now.
Who is doing the rewire then?
Sounds fishy
why would ANYBODY put the boiler in a separate building 20 meters away? That just sounds so odd.
I thought this at first too, however someone on our road this this as well (5 houses down) went to speak to them about it, and so far so good. Nothing major bills wise and they don't need to worry about using up space within the house for the cylinder etc.. One other benefit is the the plumbers are happy because they have really easy access to boiler and cylinder, normally when they are inside the house they are housed in cupboards etc... which can be a pain.
Sounds fishy
Builder bought in his own electrician who will do the wiring. However I am up for bringing in my own person? anyone here want a job, rewire whole house and the new outhouse.
Would it be cynical to suggest the OP and builder are one and the same? Of course it would be, perish the thought. Builders never do electrics...….do they?
LOL I work in IT, don't do any building work, getting loft, extension and new outhouse, etc.... just want a good and above board job done, so asking question. You guys are way to suspicious.
As I said, send me a pm and ill be happy for you to come down and quote me. I live in the East London area so you have an idea of where you would have to come to.
Almost, Mrs does a lot of baking on the side (she is thinking of starting a business etc..) Since we are having gas, electric and water running to the outhouse, we thought it would make sense to make a kitchen for possible future venture there, that's all.
Just thought I'd end the conversation here. Thank you all for responding.
As I said, happy to get alternative quotes, if you can send me a PM ill give you the details.
5 Bed
2 Bath
2 Receptions
a WC
Extension (Kitchen)
Outhouse (Boiler/Cylinder and Kitchen)
All new wiring for main house and new sockets, light switches, light fixtures.
New CU for main house
New CU for outhouse
It's a big job. The house is completely gutted now, so no need to worry about wiring runs (should be easier). The ground floor has a crawl space about 3ft and enough of the floor boards off to make wiring runs easier there.
All plaster is off the wall, and ill have the builder do any chasing etc...
5 Bed
2 Bath
2 Receptions
a WC
Extension (Kitchen)
New CU for outhouse
With the job that far advanced it's leaving it a little late to engage an electrician, doesnt sound like a great deal of forward planning is in place.
Reply to Outhouse Consumer Unit and Underground Cable in the UK Electrical Forum area at ElectriciansForums.net
