C
Cj24
Hi someone I work with wants some lights put on pir's, basically he's got 2 lights in a big room sw from 2 individual 1 way switches do has to walk past one of the lights to turn it on, he doesn't want them 2 way switching due to having to cause damage to his plaster to get strappers there so he's asked if he can leave the switches in on position and have the lights with a pir built into them so they come on as he's walking down but with leaving the switches he has option to turn off himself too, do you know if and where you can get indoor ceiling lights that incorperate a pir in them
What sort of light fitting do you need? Too many different types to suggest a certain type as the customer may not like what is suggested. Could you not just fit a recessed PIR into the ceiling leaving the existing fitting in situ?
Pir indoor lighting
Cj24,
telectrix,
