I came across a type of water heater that I haven't seen before. It has a 3 core flex attached and fits into the sink where an ordinary tap would usually go. I had to fail it as it had a two-pin continental style plug fitted and was being used with a unearthed adaptor.
My question is would it be a "pass" if it had a proper 13amp plug fitted?
View: http://i.Upload the image directly to the thread.com/gDa8Be6.png
depends if it's labelled classII or not.
What is the rating of the heater?
It may very well need to be hardwired.
Was it a 2 pin plug like this, with earth on the side and with matching adapter.
Or was it 2 pin like a shaver plug.
Plug as you show with earth on the side but adapter not matching (it would suit a two pin shaver plug). Cable clearly marked as three core.
[automerge]1591795203[/automerge]
No class 2 symbol as far as I could see.
therefore it needs an earth connection at the socket.
Common enough sur le continent...needs a matching earthed socket as stated above
[automerge]1591913736[/automerge]
The instructions are quite clear:
  • Package with a Socket Converter! Kitchen, toilet, etc ... All can use! Easy to install!
  • NOTE: DON'T test it in your hands before installing finished, that's would be very dangerous. Please operate it under the user manual."
Reminds me of the works of Keats or Shakespeare.
IW
Plug -in Water Heater
Electrical Testing & PAT Testing Forum
joolsmy,
pirate,
