Currently reading:
`pond flex` or `arctic` cable for flex connection to outside halogen lights ?
Discuss `pond flex` or `arctic` cable for flex connection to outside halogen lights ? in the UK Electrical Forum area at ElectriciansForums.net
"Hello All",
Please don`t think that this is `too trivial` a question for the Forum:
I have noticed that My Garden / Outside Halogen Lights [500 W] were originally wired with what looks to Me like `ordinary` 1mm Flex.
It looks like the Insulation has been badly degraded by the Weather / UV Light.
I want to rewire these - just about the last 800mm to the Lights - luckily there are Single Gang Surface Boxes with Flex Outlet Plates on the Gable End Wall in the Loft and I would rewire the Lights back to the connections housed in those - the Switches are downstairs - these 3 Halogen Lights / the Lights Circuit has its own circuit breaker on the Consumer Unit.
Here is My question regarding which Flex type cable I can use:
I obviously want to use a `Weather / UV Resistant` Flex / Cable.
IF `Arctic` Cable [3183Y]
is both UV / Weather and Cold Temperature resistant this would be ideal for Me as I can purchase Cut lengths of 1.5mm 3 Core for about £1.10 per Metre - I would only need 3 Metres - approx 800mm for each Light including some `slack`.
Before seeing the Arctic Cable I saw `Weather Resistant Rubber Pond Flex` [3183P] - 0.75mm 3 Core - this is described as being `suitable for external lighting - exposed to the Sun`s rays` - BUT this is only available on a 25 Metre Drum at a cost of £15.34.
As the `Pond Flex` would only be any good to Me if I have to rewire the last 800mm to these Outside Halogen Lights AGAIN I don`t really want to buy a 25 Metre Drum of it - unless the `Arctic` cable is NOT suitable - ?
As I mentioned - Please don`t view this as too trivial - the Information that I will receive on here will be helpful and possibly save Me about£12.00 [?].
Thanks for your help.
Regards,
Chris - Heating Engineer
I usually use pond cable for outside lights but I think arctic cable would be as good if not better.Check what the spec is.
"Hello sparkdog",
Apart from what I wrote the only other `identifying` detail is: 3183Y [1.5mm 3 Core / 15 Amp]
Is that a BS Number ?
I have noticed that the Pond Flex is noted to be 3183P
Thanks for your help - Arctic cable would definitely be much cheaper at approx. £3.30 inc. - instead of £15.34 inc. for a 25 Metre Drum.
Regards,
Chris
measure up for your arctic flex and then add 20%. better to waste a couple of yards than to find you;re 2 foot short. ( or we would be calling you oscar . :icon10: )
Won't bother in future... ;)
"Hello Guitarist",
I was writing this reply to You immediately after I wrote to johnuk - when I tried to Submit it I received the Message that I needed to `Refresh the webpage and Log In again` - words to that effect - I did this BUT the `Auto saved content` just consisted of "Hello Guitarist" !
I had LOST the entire message to You - and as I Type using only ONE Finger it has taken a while to Compose and Retype this to You.
Sorry that You felt I had ignored your message to Me - I assure You that I had not.
Thanks for your reply and for the information about the Grey sheathed T&E - I might have some of that somewhere but it would take too much searching to find it - I will just buy 3 or 4 Metres of the Arctic Cable.
I wanted to ask about this to ensure that I use the correct Cable.
Although I have stated that I do not carry out Electrical Work this is a very simple task at My own Home where will just be renewing the Cables from 3 Halogen Outside Lights [500W] approximately 800mm to inside the Roof Space where they connect to small Junction Boxes which are `Housed` within Plastic Surface Boxes with Cable Outlet Plates.
The Electrician who wired up these Outside Lights [22 Years ago] was a good Friend of mine who knew that I am VERY particular regarding `Workmanship` of both My own Work or anyone who does work for Me - so I think that He went `Above and Beyond` what would be seem as `Normal` regarding these `Housed Junction Box` connections.
Although without wanting to defame Him in any way this did not seem to apply to the Flex that was used externally - perhaps Arctic or `Pond Flex` was not generally available then and an Alternative / UV Protected Cable would have been prohibitively expensive [?].
BUT from what You mentioned about the Grey sheathed T&E - that would have been readily available / used every Day - ?
Thanks again.
Regards,
Chris
standard T/E is/has been used a lot outsideover time and generally will last for years, but will eventually degrade due to uv. quicker on a sunny side of the house. arctic flex or black flex is the way to go. apart from looking a lot neater ( e.g. black cable with round black clips, the satellite clips are ideal for 1.0mm or 1.5mm flex). i always use bog standard black flex. the lights are only 2A if 500watt halogens , so 0.75 mm is well adequate. one disadvantage of using flat T/E is the glands on the lights are designed for round flex.
"Hello telectrix",
Thanks for your reply.
I need about 800mm of `Flex` / Arctic Cable for each Outside Light - including allowing for stripping back and terminating the ends at the Lights and the Junction Boxes and allowing for a `Drip Loop` [excuse the terminology] externally and a little Slack internally.
The Junction Boxes are basically exactly behind the Outside Light positions in the Roof Space - so the Flex / Arctic Cable comes out of the Cable Outlet Plate - drops down abour 150mm - through the Wall - drops into a Loop and then goes up into the Cable Entry into the Light `Gland`.
I will get 6 Metres of the Arctic Cable - so as to have some spare in case the Light Cables ever get damaged [by perhaps Ladders] - so I will definitely have enough to rewire the Lights.
By the way the Arctic cable that I can buy in Cut lengths is either Bright Yellow or Blue in colour - obviously I will get the Blue [similar colour to this Blue Text] - luckily I will not need Clips.
EDIT:
Thanks for the further details in your last message.
Regards,
Chris
Had to refresh again, Chris ?
"Hello ipf",
I am not sure what You meant by your question above - but actually I have been eating Dinner.
Thank You for this message:
`As The Guitar man says, nothing wrong with 1.00mm black 3 core flex. Easiest to work with and doesn't stand out like a sore thumb`.
Regards,
Chris
"Hello ipf",
Regards,
Chris
Hi Chris, just joking after guitarist. lol. ATB.
Hi Chris, what I said was tongue-in-cheek. I wasn't upset, really.
If you only need a few feet, then pop into any electrical shop/DIY store and get yourself some 1.0mm black flex if the lighting is on a 6A MCB or 5A fuse. Arctic generally comes in blue (230v) and yellow (110v) which is not an indication of voltage rating but just a colour coding for identifying equipment on site.
As already said, T&E will degrade over time (quite a long time normally) and the oval shape isn't great for glanding if it's exposed.
Should have been 'with' not 'after', sorry G.
"Hello again Guitarist",
Thanks for replying again.
What I wrote was exactly what happened - I wrote the brief reply to johnuk and then immediately started writing My reply to You - then I could not Submit it - Lost it - and had to Retype the message - as I only Type with ONE Finger this all took plenty of time.
I can completely understand why it would look as if I was NOT Grateful for Your message to Me when a reply to You did not materialise soon after My response to johnuk - and it was exactly because of this that I wanted to add an explanation to My message.
This Losing messages has happened a few times to Me on here previously - I will have to revert to carrying out `Copy & Paste` of My messages BEFORE I Submit the Posts - so that I do NOT Lose them.
Thanks for confirming that I could use `Ordinary` Black Flex - but as I would have to go to the same Electrical Goods Supplier to get Cut Length of that I might as well get the Blue 1.5mm [1mm not available] 3 Core Arctic cable.
I had originally thought that IF I had stated that I was going to use `Ordinary / Standard Flex` I would be `Verbally Chastised` on here - with some statements such as: `You MUST use UV Resistant Cable` !
Thanks again for your help.
Regards,
Chris
Regards,
Chris
I've lost quite a few, also. Pain in the backside. Automatically logged out, half the message lost.
I MUST do the Copy & Paste process each time from now on - Most of My messages take Me a long time to Type using one finger - it is a REAL `Wind Up` when I lose what I have typed.
Regards,
Chris
Regards,
Chris
It should be auto saving but for some reason it auto logs out after a certain time.
I sometimes leave the post and return to 'forum' after a while. Then go back to the message and press the 'restore auto saved content' so that not too much is lost.
No problem using non-UV resistant cable here in Guernsey. We last saw the sun in early 2002 for half an hour - its been raining ever since. :( I've seen some pictures of it and it looks quite nice.
"Hello Stroppy",
The Channel Islands are advertised on TV as `The Sunniest place in the British Isles` ! - regarding Tourism.
Regards,
Chris
flew over guernsey last year. the sun was dazzling. that was above the black clouds, though. you need to build higher. we were at 15,000 ft.
Noooo, we are lucky to only have one tower block in Guernsey, and that is only 10 storeys high, although I am thinking about a massive sun tube out of my roof to get some sun in!
Reply to `pond flex` or `arctic` cable for flex connection to outside halogen lights ? in the UK Electrical Forum area at ElectriciansForums.net
