Discuss Flex cable for light ? in the Lighting Forum area at ElectriciansForums.net
I have a spare 2.5mm 3 core flex cable.
Can I use it for an outdoor light?
It will be connected a junction box that's already supplying electricity to a different light. It has a 1.5 twin and E coming into it. (It's the smaller wire , so I think it's a 1.5)
Many thanks.
If you mean a short loop out of the JB to some sort of surface mounted light then yes a bit of 2.5 flex will work fine, you may struggle to get 2.5 into the light depending on what type of light you have
Depends on whether the joint box incorporates cord restraint, if exposed to the elements is it suitable, are ferrules required to enable correct terminations.
Reply to Flex cable for light ? in the Lighting Forum area at ElectriciansForums.net
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi, I do basic electrical DIY like changing light fittings and have got a light to put up that only has a fly earth and no flex earth (see pic)...
What cable would you use to connect this light through a cavity wall to a FCU the other side of the wall? I am thinking, 1.5mm² 3 Core NYY-J...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
