If its a 4mm radial fine but its a 2.5mm propably protected by a 16a mcb.
I gave my opinion to reduce risk of oveload!
Or 20A...
But I think the questions more being asked because people have suspicions its going to be on a 32A...
green king is OK. as mentioned previously, hobgoblin is moreish and theakstons old peculier is even nicer.
Recently i have wired a small dwelling house.
I have used 2.5 mm Wire for a radial circuit of 2 double and 2 single sockets. (probably the cable length of 35 m)
I am a bit conscious to know whether it will work for longer time. or i will need to make it a ring circuit.
WHAT DO YOU SUGGEST?
So you have already "wired it", and now you are asking us whether it will work for very long?
I'm guessing that this should be in the DIY section.
tapestry? more like tap room
