J
Jayjaytb
Hi I have just renovated a cottage and installed a woodburner with back boiler for HW and CH, The hot water system also includes a immersion heater. I currently have a on/off switch to turn on my CH pump. I'm looking to automate the system installing a high pipe stat so as to initiate the pump when the H/W cylinder gets to 60 degrees. I also want to instal a low stat to turn off pump when the cylinder drops below a certain temprature so as to try to prioitise a tank of hot water over C/H. Also I was hoping to fit a 7 day timer to the Immersion so as through the summer months when fire isn't lite I have hot water, also so there's hot water when I come home from work as the fire will have been un lite. I am looking for help with a wiring diagram and to make sure the timer on the immersion will be ok on the odd occasion that I'm home and have the woodburner lite at the same time as the timer kicks in
sorry if this has been covered previously but I have searched relentlessly and cannot find answers to my questions
many thanks
Jamie freeman
many thanks
Jamie freeman
