Currently reading:
suitable j/box in loft are
Discuss suitable j/box in loft are in the UK Electrical Forum area at ElectriciansForums.net
Not a lot to day so yet another question. Got several (about 10) 1.mm lighting cables to join together in a loft space which has about 300mm + loft insulation.
Years ago I would of used a J701 j/box with chocs blocks. Anything better on the market now? Would you guys fix the j/box above the joist level and the remove the insulation so as not on top but still some underneath?
I use Wiska boxes and Helleman/Wago connectors. Easy to see what you are doing and very clear. I some times print flag labels off and attach them to the incoming cables (i would with yours if there are 10 cables). I will try and find a picture of one i have done....
With that many cables to join i would use a double pattress box and a combination of wago's
I'd never seen Wagos until last weekend. The ones that I saw had 2 x terminations (holes) I think on the box it sais 2.5mm. Would that of meant up to 2.5mm. I'm assuming 1 x terminal 1 x conductor only, as opposed to getting 2 x conductors into 1 terminal. I would want to connect several conductors together,, typically the Live / Neutral conductors not forgetting the CPC's
I've already written on them in inedible ink, better than pencil lol. But yes, be great to see what you use.
[/URL][/IMG]
Why wouldn't it comply? It comes with a small mounting bracket so as not to compromise the IP rating of the box but you can still fix it securely to a surface and the knockouts are rubberised so you can poke cables through. Although they do have internally threaded sections so there is no lock nut required when putting a stuffer in there.
Yes just saw on their site about the rubberized knockouts, looks good and on you tube re the gland idea. going back to the Wagos, would I need a whole array of different sizes? I'm very comfortable with the choc terms but I'd like to keep up to date if it makes the installation even safer.
PS is that rated at 20amp. Been looking on there site.
Cables should be securely held in place, by glands or clipping up to the enclosure etc so as not to place strain on the connections should the cable be pulled on or the JB knocked.
It is an inspection item on the EICR
Have a look in screwfix
As Dave has said, in its current form it would not comply as there are no cable grips!
Looks neat, thanks. Basically a few feeds L+N's + a couple of 3 core sw/wires + several cables to lights. Are those boxes pre-wired then? Would that restrict my wiring options as opposed to starting from scratch?
Yes they are pre wired, i have found no restrictions with them. The only downside being that with the short connections on the push fit terminals, if the wires are connected it is hard to tell if one is loose, just takes a little extra checking.
I clip the cables once the box is secured.
Although i have been guilty of leaving jbs loose(ish) in certain situations. I only use glands with Wiska boxes when they are either on show or in a potentially damp environment. Because i am a tight arse!
Good point but I've not come across it
It's crap mate. I used it on a rewire then spent 20 minutes identifying the seperate conductors. At least with standard brn/blu you know which is your switch feed and return.
Nice idea but pointless. I am probably going to end up using it as standard t and e and sleeving one of the browns blue lol
Reply to suitable j/box in loft are in the UK Electrical Forum area at ElectriciansForums.net
