Discuss Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
find the joists, chip plaster from under joists and about 1" to each side. fish cable from one joist to another, wire up lights, clip cable to underside of joists, tub of poyfiller, bit of rag to blend to match artex if required, jobs a good'un.
do you the put strip of plaster board back in, then polly fill.
so if was pentant would would you just extend off that using wagos or something
When fitting downlights I generally use the 16a Ashley, hager junction boxes which have same terminals as a pendant loop in and out in the top and one coming out the bottom to the fitting. Find this is the neatest and safest way.
They also have cable clamps so fulfills the regs and aslong as you leave enough slack so it's accessible for maintenance it complies.
fire hoods stink! seriously if the fire hood ever had to be utilised for what it is then the flames must be licking the ceiling and the house is a gonner any way!!
i just fir fire rated lights! simples!
Fire hoods where a great money spinner for a time. The fear around not using them against the truth of how they really work in real life !
Reply to Wago's , junction boxes and choc blocks whats best with downlighters in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
