The extra yield predicted isn't that great. I can imagine at certain times the increase may be 30% for a short amount of time but the modelling doesn't suggest that this would make much difference over the year.
The 30% wasn't across the whole day. It happened to be during the peak sunny periods in the summer (remember that :) ) when we did the experiments, and we were only measuring instantaneous power, not total energy for the day..
I had a very similar problem to this when my system was installed and received a lot of help from this forum the thread is here http://www.electriciansforums.co.uk...ergy-forum/53090-correct-inverter-choice.html
Here is a picture of my shading.
In addition to the chimney I have shading of the bottom panels during winter from nearby trees.
You would have to read the thread to get all the details but the system performed very badly and we changed to SolarEdge.
I have been very pleased with the SolarEdge system. For me it seems to have been a very good solution. The extra cost was not that significant (this was installed when a 4Kw system cost 10-12K) You can also factor in the monitoring which is something you might might have to pay for with other systems.
What the monitoring does prove is how much is lost per panel due to shade, see image below which shows total output per panel since installation.
This shows that there is not much loss due to the shade with SE installed, before the loss was huge albeit on a poorly installed system.
The only downside for me has been trying to deal with SE as a consumer. They really don't want to deal with consumers and for this reason getting the monitoring setup was a nightmare. I still don't have full access so I am unable to update the tariff changes when they happen which is really disappointing. If you do go down the SE route make sure your installer is willing to register your system and update tariffs in the future because you cannot do this easily yourself.
Hope the above is useful.
come on geordie. knock it down is a plumber's solution. as electricians we would carefully demolish it brick by brick, stacking said bricks neatly in the garden for the client to make a water feature from it, being careful not to shade his PV array.
Sorry Tel ... I wasn't thinking - must have been a "Senior Moment".
I would strongly recommend people research manufacturers financial situation a certain microinverter company aren't posting great profits compared to solar edge who seem to have it cracked. Enphase and solar edge are made in the same factory in china so quality is there on both products, as for bypass diodes conducting on micros it has a great effect and can totally knock out the inverter making it useless in shading conditions, but as for solar edge it works on a fixed string voltage and is not reliant on min voltages coming for panels the optimiser and inverter work together to adjust the voltage on the panel to optimal output, Dc to dc optimisation is the way for my company and it does not cost 1k extra to install either around 600
Good thread. Very educational and great contributions from many sources. A couple of thoughts:
1) Have you considered reducing to 14 panels and increasing wattage on each? You could get rid of that 6.7% stinker. Maybe go for Yingli 275s x 14 = 3.85kWp. Combined with the Power One 3.6, this might work ok. Or even BenQ 325s x 12 = 3.90kWp and kick out 3 weak performers.
2) Have you considered going over 4kWp and installing on the opposite roof surface? You could cover both sides and go for G59 or maybe just a few on the other side and stick with G83. Yes, it would increase the overall cost, but it might reduce the pence per watt/peak figure. It could be a real goer with an Immersun-type device. The FiT level isn’t that much lower for the 4kWp-10kWp band these days (13.50p v 14.90p).
Thanks for the info. In what way was yours a poorly installed system?
It was a rush job to beat the FIT tariff drop deadline in December 2011.
Fitted on two strings the voltage was not high enough for the inverter. The inverter was not a good choice where you have shade, there are much better choices such as SMA and Power One.
The standard of roof work and internal cabling was poor although this was partially rectified when the installers revisited to install the SolarEdge.
My best advice would be take your time, do your research and preferably use a contributor from this forum for the install. It looks like you are doing all three so will probably get it right.
Hope that helps.
What is the best way to overcome the problem of shade from a chimney?
compmad1,
Dave-geo,
