Search the forum,
Discuss Whats the oldest type of wiring sytem you have had to work on/repair/replace in the UK Electrical Forum area at ElectriciansForums.net
A couple of years ago I had the joy of trying to get lights back on in a place wired in VIR cable, wired in singles with no conduit.. The fault was a loose connection at a switch but the owner had taken a light fitting down. I fixed the switch ok (the insulation was quite good - no cracking) but the neutral at the light kept cracking as I bent it to terminate it. I ended up putting a lengh of heat shrink over it and then bending it. It worked a treat and got the lights back
I have since rewired the place
I've worked on all the above, not least because we get asked specifically to look at older installations. Sweated lead joints and refilled the sealing chambers with compound. About the only two things I haven't done from scratch are install wooden casing, which is an art in itself, and vulcanised rubber joints in-situ. Working imperial MI is interesting because the cable is potentially good for another lifetime, if only one can maintain the terminations in a practical fashion. I do still have a few NOS seals and tooling but often one has to improvise. One of our last mainly original VIR-in-conduit systems from 1928 has recently come out of service although some of the original fittings are being re-used. It is a pity that most of the genuinely interesting stuff has gone now, if I had started collecting sooner it would have been so much easier.
I've got a pdf somewhere which lists all of the imperial micc sizes with the metric equivalent sized glands and pots which will fit (sometimes with a little soldering)
There used to be quite a lot of lead sheathed, rubber, RBJ, singles in casing or slip conduit around, don't see very much of it now. There is a farm house with 1930s wiring, wooden Kantark fuse boards, porcelain ceiling roses etc. The cables are in very poor condition, sections of insulation have fallen off of some of the surface cables. Every time I got there to fault find, all I can do is disconnect the faulty circuit. We priced to rewire the place 10 years ago, and keep telling him but he still won't spend the money, what's worse is he's minted, typical farmer. He turns the main switchfuses off before he goes to bed or leaves the house...
It's probably a good thing a lot of older stuff has gone as I seem to hoard it, I even have a load of old Crabtree switch and pendant cartons. Some of the stuff is quite old, but all of it still functions. A friend has a lot of much older light switches and a few light fittings, late 1800s stuff, decorative but robust with no tools required to access the tingly parts, he has them installed in his house. One of his light fittings has ES lamps, the threaded cap connected directly to the metalwork of the fitting, and a single core connected to each of the centre lamp contacts.
Before BICC stopped manufacturing Pyro in Prescot if we needed seals and glands for imperial cable and no metric equivalent was available we called the factory and they would drill out pots and glands to suit the imperial cable. Turn round was quite quick and if we needed them in a hurry the factory was only 10 minutes away
Not part of the electrical supply, but we maintain some old wiring installations that are part of large pipe organs that have their original electric action. As an example, the Southampton Guildhall Compton still has all its original cotton-covered wiring from 1937, all in excellent condition. Top of head there is some 100 miles (yes, miles) of single-core DCC 26SWG wire, loomed up with cotton tape or lacing cord into bundles typically of 61, 73, 85 or more cores. The largest bundle is about 2,000 cores, while the console cables of maybe 600 & 800 cores respectively actually unplug with giant multipole connectors. All of this works at 18.5V DC, for which the total supply is about 100A continuous, 300A peak, from a belt-driven dynamo. The mains and submains are still in VIR, in good condition, of which the largest is something like 19/.064 (about 40 mm²).
Some of the workmanship is quite spectacular, hundreds of connections all fanned out with not a single wire 1/16" out of place. I'll dig some pics out later.
Me & the Mrs used be members of the National Trust. One of the last places we visited, was Tyntesfield in North Somerset. It was acquired by the Gibbs family in the late 1800's. They made they money by making fertiliser out of bird ----.
It was bought by the NT, when the last of the Gibb's family, Richard, past away in 2001. He used only three rooms in this mansion. Public were granted access, during its restoration. The whole place was covered in dust, and the musky smell was quite strong. It had a games room, which had (at the time) the latest 'billiard' or games table with automatic mechanical scoring. The Grand Staircase carpets had been trashed, by contractors. It contents were catalogued and included, an unexploded Second World War bomb. By 2013 the inventory had risen to 47,154 items.
The restoration of these places, use some trades that have fallen into obscurity, which requires the acquisition of new trades & apprentices.
Ohhh, and it had some really old wiring in it, which was replaced with some nice shiny new MI (I never worked on any of it).
A plug for the NT, its about £65 a year pp. Worth it for entry, to some of the most fabulous & fascinating places to see (big & small) in England, Wales & NI. :)
Stripped out a load of stuff from an explosives factory 20 years ago. The nitro mixing tubs (lead lined wood) still had the original 1920s cast iron switchgear and oil bath switch still in use until the place closed.
When we rewired the local scout hall (first place in town to have electric) there was tons of old wiring still in the original wooden trunking, plus pipework for gas lights, concrete bases for the generators which we had to break out and found the exhaust pipe and silencer still buried in the ground. Some wiring was still in use as it had been a photo studio since the 1930s and a cinema before that.
On the subject of old stuff, anyone come across ballast lamps in use with old fluorescent fittings? Grandparents house had some in the attic, looked like silvered bulbs in a bayonet fitting except they had 3 locating pins not 2. Never sure how they worked unless they were similar to a modern starter.
As an apprentice, same as others.. old farmhouses, VIR in imperial conduit.
Metal rocker switches. Our job one day was to remove the switches, solder a trailing earth wire on the back of the plate, drill a hole in the back box, M4 thread, and screw in an earth stud.
We had rewired in singles back to an existing joint box.. with cpc's.
The biggest gripe of the homeowner was us lifting a frayed of carpet off the landing. 100 year old and then some. Frayed, threadbare and faded.
I've never seen those wooden fuseboards.
Got to work on an old 1930's (i think) servants bell system recently. 24v dc on bellwire. Pushbutton in each of the main rooms to a bell-and-flag board in the kitchen. All but one original pushbuttons worked perfectly.. last one got damp, and is all rusted inside.
Reminded me of the other things you find in old farmhouses;- Original mechanical wire and pulley systems for calling the servants. The wires just got in the way trying to crawl through the cobwebbed attics.
Wooden capping and casing, a surface method slotted wooden base with o wooden lid with VIR singles
I recall bell & flag system in my parents house, a four bed semi built early 1900's. It was ripped out, when they had the place rewired in the 1960's. Wasn't a place you would of thought, that would be having servants, but I expect it was the latest much have gadget at the time. The old wiring was a mixture of rubber insulated & sheathed and singles drawn in slip conduit, not sure or the correct terminology. I've attached a picture of a switch drop in the kitchen.
The property had a 210' rear garden, which my Dad used mainly to grow his own veg. Sadly, the two semi's are due to be knocked down, and flats built for student accommodation. He'd be turning in his grave. :(
I can just about remember being taught how to prepare those wooden blocks the switch is fixed to, drill the holes where you want the single cores to come through from the back then the fixing holes, a right ball ache it was.
They took the place of the choke for ballasting on DC mains, negating part of the efficiency benefit of fluorescent but at the time there was no alternative to a resistive ballast. Obviously they would work on AC too. There was also the 'Starterlamp' which was a 4-pin starter with a GLS ballast lamp mounted on it.
Anyone remember twin rubber cable, we used to use it at Christmas time to string temporary decorations on shop fronts, also the lamp holders that you screwed down on to the cable, they had two spikes which perforated the sheath of the cable and made contact with the conductors, think they were called something like B&T lampholders, anyone know the correct name for them?
'Beeantee' is the trade mark, they are still available. They have to be used with the correct 6192P festoon cable to ensure correct contact and sealing.
Good Man Lucien thanks, that's been bugging me for years.
Reply to Whats the oldest type of wiring sytem you have had to work on/repair/replace in the UK Electrical Forum area at ElectriciansForums.net
