Search the forum,
Discuss Wiring a remote light switch to a wall switch advice. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
buabba
Hello everyone
I am new to this forum and will like some advice in installing a remote switch to a standard one gang wall switch. I cannot seem to get it to work and is getting a bit uneasy about trial and error. I have attached 2 pictures.
I have tried to insert the red wires in the in and out but it did not seem to work. DOes this switch behave like a electrical plug and I need to activate the black and green/yellow wires?
you need to put the live feed in L in, the neutrals ( black ) which are joined into N in and it looks as though from your pic that there are 2 live outputs for 2 separate lights. use one of them for your switched live
Cheers telectrix
So it is
N-IN : both Black wires
L-IN : single Red
OUT-A : single Red
What does the yellow and green ones do?
exactly. leave the green/yellow as they are. they are earths and must be together for the light fitting to be earthed, but the switch does not need them. as jason says, you have to determine which red is which. the one that makes you jump is L IN
better still, use a neon screwdriver to see which is the feed.
no way intermediate. it's an electronic switch needs L/N feedto power it. the original switch has been put in line with the feed to the light so one red is Phase in and the other Phase out. Neutrals JB'd together.
sorry Jeremy, thought you meant the new switch. looked at pic of existing switch and it does look like it. could it be that it's a 2 pole switch and buabba has put the reds in the wrong holes after trying the remote switch?
Op states wiring to a switch so thought that the remote switch was, well, remote. But a bit confused why you would want to switch a switch? Sort of need full details. Ps if you're going to crimp use the right size crimps and use both ends or you've got an open end, just a tip!
The remote is like a TV remote withthe sensor on the wall. I am using this device as the light switch is inconvienently hidden behind a door. electric 3.jpg
as i see it, he wants to replace the existing rocker switch with the remote one so he can watch TV with the lights on or off without getting up. wish someone would invent a remote beer fetcher. OH, just realised, iv'e got one. it's called her indoors
Well at least 'her indoors' do not need so much wiring? or does she? I want a remote to clean, iron and cook dinner too. :p
I will try to wire the thing up later. Thank you for all your help!
mine cooks, cleans irons, works a 100 hour week as well. wouldn't swap her for the world, but might consider a megger 1553
another thing mate, how have you crimped the earths and neutrals together? i doesnt look like you have use the correct tool, and over time they could become loose and cause you no end of problems, the worst being that they could start a fire (neutrals). Also its bad practice to double up in crimps like that, put a cable in each end, and use the right size. Red is for upto 1.5mm2, blue is from 1.5mm2 upto 2.5mm2 and yellow is 4mm2 to 6mm2.
Well to be honest I am not very sure. But I know the current light switch has the reds passing through to provide power. The black and yellow/green ar enot used. I am located in UK, so does that help with any of the colour coding? The wiring was already there when I moved in.
god, this is getting too confusing.
1. identify the "live " red with a neon driver ( power on ) . if you not got one, £1.50 from any DIY store.
2. Turn off power, put said live in LIN.
3 Remove crimp fro blacks and pu both in NIN
4 Make sure earths ( green/yellow) are joined together and not to anything else.
5. Put the other red in either of the other terminals.
6. Switch on power. it will work. Trust me, i'm a doctor.
telectrix, you shouldn't be advising people to take switches off with the power on, never mind to poke a cheap screwdriver in there.
There are safer ways of determining which wire is which, like belling it out (with the power OFF)
i stand corrected. i meant for him to test with the switch still connected. To bell out the cables would entail him going into the CU
. Not recommended for the average DIYer
You shouldn't even take the switch plate off the wall with the power on.
Belling out is nothing to do with CU.
I mean bell out the cables between light switch and ceiling rose to see which is the switch line.
Wouldn't advise my worst enemy to use a neon screwdriver might as well tell the op to lick his fingers and touch the live cable.
The only advice I will give here......contact a qualified electrician. And DO NOT go and buy a "neon screwdriver" to test anything!!!
Agree with lenny, consult a qualified electrician..........And dont use a neon screwdriver from the pound shop, from china. cant think of any proper sparks who would even mention the word, let alone have one proudly in thier kit!!
neon driver more reliable than a volt stick. find me an electrician who hasn't got one!
both are useful in their own right, as a quick guide. i was trying not to make the issue too complex.
I haven't got one and won't allow any sparks on our sites to use them. Any electrician worth his weight would not have one of those stupid things anywhere near them.
By the way a volt stick is 1000 x better & safer IMO.
ok, we all know neon testers and volt sticks are not reliable. We've all had volt sticks lighting up on "dead" cables. ideally he should use a proper test meter ( calibrated of course ) but as I said earlier, was trying to keep it simple. Off to bed now ( orders )
1. identify the "live " red with a neon driver ( power on ) . if you not got one, £1.50 from any DIY store And possibly blow your hand off
Why not call your local electrician and ask him how much it would be to change a light switch that way it will be done correctly and you wont risk endangering your self
Reply to Wiring a remote light switch to a wall switch advice. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, i’ve been trying to buy a smart switch 1 gang 1 way but i opened my conventional wall switch and i only have 1 red wire(Live Old UK) 1 black...
Hi brains trust, I am aware of typical wiring and legalities hence the questions. Looking for a wiring diagram to allow me to use a dual switch...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Good Morning need some advice please. Yesterday went to change a light fitting in hallway. There are two ceiling lights in the hall controlled by...
