Search the forum,
Discuss Wiring up 8 x 230v 35w downlights in the UK Electrical Forum area at ElectriciansForums.net
Ok Custie, am I right in thinking that the two existing pendants are switched on together ?
If so the pendant nearest the switch will probably have 3 cables, a feed in, a switch wire and a switched live & neutral to the far pendant. I'd replace the switch wire with a 3 core and CPC giving two switched returns and install a MF junction box above where the pendant with 3 cables is now. Then just run a new T&E from there to each bank of lights looping in and out, the s/l and neutral to the end of circuit light can be replaced or used to feed the first downlight on one of your 2 banks.
That was the answer I was looking for Dave and appreciate you taking the time to explain it to me. Much appreciated, Pal.
Two disagree now that domestic work comes under part P.
edit. I never said it would need notifying, but compliance with part P is still required, and as such it will require testing and certifying in accordance with Bs7671.
It's good to know you guys in England all know what work comes under Part P, it sounds like a glaring success:(
I know exactly what's notifiable, sadly WP doesn't seem to have grasped it just yet. :rolleyes:
Wirepuller - You're just being pedantic and deliberately awkward now - you were wrong in saying that this particular job comes under Part P,it's an alteration to an existing circuit and not in a special location, no point in trying to play on words just admit it.
ALL domestic work comes under the scope of part P whether it's notifiable to BC or not. Part P dictates that all work in a domestic location must be designed and installed in accordance with Bs7671. That means a minor works form must be issued for any alteration or addition to an existing circuit. You are wrong in saying it does not come under part P because it is not notifiable.
Reply to Wiring up 8 x 230v 35w downlights in the UK Electrical Forum area at ElectriciansForums.net
