Discuss Wiring up 8 x 230v 35w downlights in the UK Electrical Forum area at ElectriciansForums.net
Hi all, this will be my 2nd post as a member.
I want to replace my existing pendant lights in my living room with 8 x 35Watt GU10 led downlights. Was just wondering about the best method of wiring these together so they can be operated from a two way dimmer switch. Ie: In two groups of four.
Really appreciate any help with the above.
Cheers! :)
I think you're a bit mixed up with the wattage there, 35w halogen downlights would be about right using 8 in an average lounge but the LED equivalent would only need 6 or 7 watts for the same light level.
There are many ways of doing this job but as Murdoch said you really need a competent electrician on board as it could get a bit involved.
What size is the room?
Dimming just 4 LED GU10 lamps can be troublesome. Enlite 5w (520 Lumens) Lamps and the Aurora Dimmer Module I find work well together, and are easy to configure for minimum brightness.
Personally though if using a dimmer I'd stick all 8 on together with 1 Dimmer, rather than have 2 zones.
2 pieces of advice
1. 35w LEDs will be extremely bright and very expensive
2. Get a spark ....... And a plasterer
Hi Murdoch.
Okay, I'll rephrase the question,
I want to replace my existing pendant lights in my living room with 8 x 10Watt GU10 led downlights. Was just wondering about the best method of wiring these together so they can be operated from a two way dimmer switch. Ie: In two groups of four.
Many thanks!;)
Hello, 123.
Thank you for your mature and informative response. The living room is quite large. Approximately 3x7 metres . If I go with your method, I'm confident to carry out the work and daisy chain them. Thanks for the info on products, I will look them up.
Cheers mate. Much appreciated.
i'd use 12 x 5watt, in 2 banks for a room that size. that will give you 1m spacing. 2 groups of 6, and a 2 gang switch.
How many existing pendants do you have and how are they connected, looped at switch or looped at pendants.
Roughly 3x7 metres, Gents. They're looped at the pendant with the furthest pendant from switch being the end of the downstairs lighting circuit. Before you's bite my head of guys. I'm a trainee spark with a little experience, Levels 2 & 3 C&G 2365 and 17th edition. Yes, I could pay for a real spark to come in and do a perfect job as money isn't a problem but I would get no experience from it. I understand basic lighting circuitry and how to safely isolate so I think with the correct knowledge, I am more than capable of completing this work and at the same time staying within the confines of the law.
Cheers guys.
Way overkill imo. And in LED terms, wattage means nothing. Enlite 5W Cool White are 520 Lumens, other brands can be around 300-350. Ceiling would be like a Swiss Cheese.
As it comes under part P you will have to carry out the work in accordance with Bs7671. Which means testing and certification in accordance with Bs7671. Failure to do so is against the law.
Maybe I have misunderstood. I was under the impression that a homeowner can make additions to an existing lighting circuit without notifying building control.
it's a big room 22 ft x 10ft. my method has always worked for me and customers have been happy. nothing worse than installing lighting to have the customer ask you for the loan of a white stick or a torch.
Hardly a big room. You must be fitting garbage lamps or fittings then. 12 @ 520 Lumens per lamp is over 6000 Lumens, and for a Lounge, only thing Customer will need is Sunglasses and a dimmer would be an absolute must.
10ft x 23ft .
smart arse. i was allowing for the ceiling coving.
I would agree that having the lights on 2 switches is a sensible idea - who is going to be doing the plastering?
EDIT : Is your lighting circuit RCD protected?
If not changing the switching, why does it need to be?
Things must be very different in England to here, 3m * 7m is not a big lounge, why on earth would you want the lighting switched in 2 zones especially if using a dimmer? 1 dimmer for all lamps and a nicely consistent lit room. Failing to see the benefit of having half of it switched off at all tbh.
Hi Murdoch, Yes RCD protected. I know a plasterer who will do the work for next to nothing. Mates rates n all. As 123 mentioned without the 2 way switch I could easily do the work but I'm unsure of how to wire it for the 2 way switch for 2 x 4 downlights.
Ok Custie, am I right in thinking that the two existing pendants are switched on together ?
If so the pendant nearest the switch will probably have 3 cables, a feed in, a switch wire and a switched live & neutral to the far pendant. I'd replace the switch wire with a 3 core and CPC giving two switched returns and install a MF junction box above where the pendant with 3 cables is now. Then just run a new T&E from there to each bank of lights looping in and out, the s/l and neutral to the end of circuit light can be replaced or used to feed the first downlight on one of your 2 banks.
say no more!
You don't need a 2 way switch. You need 2 single way switches. They may be on one plate. Lets call it a dual switch, or in your case a dual dimmer.
That was the answer I was looking for Dave and appreciate you taking the time to explain it to me. Much appreciated, Pal.
Two disagree now that domestic work comes under part P.
edit. I never said it would need notifying, but compliance with part P is still required, and as such it will require testing and certifying in accordance with Bs7671.
It's good to know you guys in England all know what work comes under Part P, it sounds like a glaring success:(
I know exactly what's notifiable, sadly WP doesn't seem to have grasped it just yet. :rolleyes:
Reply to Wiring up 8 x 230v 35w downlights in the UK Electrical Forum area at ElectriciansForums.net
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi, asking for a friend in Australia. She wants to install two Pendant lights over a kitchen island and four downlights all on the same switch...
Hello wonder if anyone can help. I have installed 6 led downlights that I would like to be controlled from a 2 gang dimmer, 2 banks of 3 . Have...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
