Currently reading:
metal capping not needed according to 17th
Discuss metal capping not needed according to 17th in the Electricians' Talk area at ElectriciansForums.net
Imho it's good practice to keep all chases as slim as possible. To me it's pointless widening a potential 15mm chase for the sake of a pointless bit of capping when there's not a chance in hell of a plasterer's float going anywhere near your cable, bare walls are usually dot and dabbed round my neck of the woods so it's pointless there too, there are alternatives in a commercial setting too.
I just don't like the stuff. If specced I'll happily put it in but I avoid it where ever I can
The way I was taught is to use plastic capping on new walls and oval conduit in chases in existing walls.
There is no sense in cutting chases wider than they need to be just to put capping in, yet I've seen so many people do this.
When we finally got a chasing machine we would cut 24mm wide chases and use 25mm oval, with the aid of a bit of tile batten it would tap into the chase an wedge tight with no need for any further fixing. It made the whole process pretty quick.
How do you guys fix the oval conduit to the wall? I have never used it and tend to use capping on jobs where i don't know the plasterer and when working along side a couple of plasterers i know locally then as Trev said, i prefer and they prefer a small neat chase!
Either a chase slightly narrower than the conduit and put a black on the conduit then give the block a good tap, or a couple of capping nails either side of the pipe, or for the narrower oval then a 2.5mm T&E clip or two works.
Interesting, how much is a length of oval then and what sizes does it come in? Might buy some tomorrow and give it a try.
Middleton Electrical Services has never needed to rewire a drop but you never know it may happen at some point so i think i may give these oval shenanigans a whirl!
I don't do domestic work so it's not a big deal but I've never seen oval conduit, I don't think it's available locally. Is it fairly new in the UK or has it been around a while?
Interesting to see how others do it. We go to the effort of drilling, plugging and fixing the oval to the wall with galvanised steel band on new builds and existing properties
This side of the pond its 20mm conduit that's generally used, chased into the wall of course. You'd get some strange looks if you turned up with capping or just clipped them into the track.
Either wedge it in or a little bit of bonding will do the trick in a hell of a lot less time
Interesting to see how others do it. We go to the effort of drilling, plugging and fixing the oval to the wall with galvanised steel band on. Ew builds and existing.
i guess others work as tight to the regs as possible to save time and money. if you dont fit capping and use clips its a massive time saving as well as a cash saving of not buying the stuff,
its understandable.
my working practice includes pointless waste of time capping
its understandable.
I've found oval conduit to be quicker than clipping in to chases. I use capping on new/unplastered walls.
There's no sense using capping in chases as you have to make the chases so much wider.
yes it does make sense and as you put it, if the chase is nice and tight to the cables then damage is unlikely.
its quite funny how people like me get set in there ways. I also screw and plug it lol
the makers of oval tube also make the clips to fix it with. 1 plug& screw per clip then snap the tube in. sssiimplesss.
I've seen them for sale but not used them as thought they may hold it off the wall and have to chase deeper. How have you found them to be? I have always used 1 1/2 x 8 screws and reds plugs or sometimes clout nails to hold it back on edges before plastering.
Yeah it's never going to stop a nail when this is what's used to secure it in the 1st place, I think a lot of newbies forget that small detail!!
I also have never used it , what use is it , cables have to be run in prescribed zones , pvc oval capping is what I use, see no use for it myself...
One thing I have noticed when I have seen it is the very sharp edges on the ends of the capping , not good , when I noticed it already in place I had to bend the edge outwards and tape the edge up , I would and never have used it ...
Reply to metal capping not needed according to 17th in the Electricians' Talk area at ElectriciansForums.net
