Discuss Part P Face and my view on it in the UK Electrical Forum area at ElectriciansForums.net
Maybe we should all club together and start another scheme - it seems anyone can do it! Licence to print money! But then I think a good conscience would get in the way of actually admitting enough members.
Not a bad idea at all. Estate agents did exactly that by starting onthemarket.com, as many of them were getting charged exorbitant rates for being on Rightmove.
Would take some effort and organisation though.
Our "electrician" is coming this afternoon to discuss the problems, doesn't know I am coming to greet him with a cup of cold tea:D
So just been to see our NICEIC registered electrician. Apparently the radial spur has a fcu in the loft so okay. The cable on block connectors in the cavity was apparently the way my sister in law wanted it connected because there was no other way and this was how he advised it should be done! Asked if he thought this was acceptable he just shrugged and said how would you do it, err just fit an outlet plate. Asked about rcd protection he just looked and said board needs changing, I asked if he assessed the existing circuit protection, he said yes but just went ahead because it needed doing in a hurry. I have suggested he fit an rcd spur by the board which never occurred to him. I said I found it hard to believe he was going to issue Certification for compliance with Part P to which there was no reply. He is returning tomorrow to rectify all this but I could not get an answer as to how he connected the downlights but pulling one down is likely to cause damage. Sadly if he rectifies all this I won't be able to peruse it further and that is wrong because you should be able to complain to the scheme provider immediately.
Any photos?
Can you Jump in the loft to see how the cables connect into the lights? Think you mentioned a loft in the post?
Any photos?
The loft space is extremely restricted and the plumbers did say he accessed it and whilst I know this spur is all but inaccessible I had to be careful how far I pushed it because my sister in law worries about every slight thing.
Reply to Part P Face and my view on it in the UK Electrical Forum area at ElectriciansForums.net
