Discuss DNO fuse - who can remove it? in the DIY Electrical Advice area at ElectriciansForums.net
My DNO SSE (some others do as well), have a written policy that gives permission for electricians registered with an approved scheme (they don't include Stroma ), to pull their main fuse to carry out certain tasks (like replacing main tails or CU). They will supply temporary sticky seals (no Phocidae jokes please), for you to re-seal and inform them with yours & seals details etc.
You should check out your local DNO policy on the subject.
I dire any body to challenge me on pulling a DNO cut out .
send in the men to pull the fuse . or see you in a few hours or put me in a 100amp isolator.by the way I have not seen one isolator fitted out by the suppliers for smart meters yet .
Several years ago, while registered with Elecsa, I applied to SSE for some temporary seals. I'm now registered with Stroma. Am I now prohibited from using the remaining seals?
Hi guys.
You need to be WI-1 and OP3 authorised. Amen!
Your lot came down here a few years ago on a raid and stayed - SSE. They allow us mere mortals to pull their main fuse if I'm a sparks registered with a CPS, no idea how that fits in with WI-1 or OP3, whatever that might be?
Hi....thanks for all the advice.....can someone tell me what an OP is?May take the OP a while to reply, think the power to his property has suddenly gone off....
I fully understand why professionals are a bit skeptical about "mere mortals" asking questions about how it all works but I can assure you that I have no intention of going near the main fuse no matter what you may think. I am an amateur and always will be but that doesn't preclude me from learning how things work. I also follow a lot of what NASA does but that doesn't mean I want to be an astronaut! In any case thanks for all your replies.I wonder why the OP wants to know this?
Reply to DNO fuse - who can remove it? in the DIY Electrical Advice area at ElectriciansForums.net
