Currently reading:
Kitchen Socket Circuits??
Discuss Kitchen Socket Circuits?? in the UK Electrical Forum area at ElectriciansForums.net
Thoughts please... probably heard it all before ;-)
At some point I will be having a new kitchen fitted and I am going to be carrying out all the electrical works and any advice on the modern wiring methods of today would be appreciated.
I'm used to the old wiring methods, where it was about switching appliances below on/off from above the worktops. Fast forward and its all about hiding stuff away with hardly anything on show. The kitchen fitters love it, my electrical friends love it who are actively installing new kitchens and so does the wife :)
Below is what I've been toying with in my thoughts.....
Option 1: Dedicated RFC for appliances on a grid switch setup mounted on the back of a wall unit switching un-switched s/s/o mounted behind the appliances from each named d/p grid switch. General sockets above worktop to keep on existing house RFC. Cooker Switch to be mounted next to grid setup. Fridge/Freezer possibly on its own dedicated circuit and combo/microwave on another dedicated within the grid setup. (Everything in one place)
Option 2: Dedicated kitchen RFC only with sockets for all appliances in adjacent cupboards with general sockets above the worktop on the same RFC. Every socket on the ring and no un-fused spurs. (Everything else the same as above regarding Fridge, micro/combo)
Option 3: Old School method.... in the past apparently.
lost count of the number of burnt out grid switches i've seen. some just defunct, some bridged out due to failure. only ever fitted 1 4 gang grid for kitchen appliances. bit me in the arse when the freezer switch failed and customer hit me with a £300 bill for ruined food. never again on my watch.
If it was a fault with the grid module and not an installation error then I'd be chasing the wholesaler about the bill for that...
Unless you bought it off ebay or the like, in which case good luck chasing that up
Not sure about that one... why without sounding rude?
I've heard of quick flow connectors on appliances that have had there plugs cut off? A bit like the flex outlet method of old which I never liked.
With Integrated appliances, Dishwasher especially but some makes of Fridge/Freezer and other appliances...there is no space for the plug & socket so the appliance can't be pushed back.
When it's the plug or socket that's faulty .......
Each to their own ....
The 18th should explicitly state how these connections should be achieved.
Why should it? I don't see a need for BS7671 to give a step by step guide of how every installation should be done.
Tumble Dryers aside I think I have yet to come across a plug that's gone faulty on a domestic appliance without another fault present.
I have lost count how many times a tripping rcd has been traced to an appliance with the plug in an inaccessible position
Switch all grid switches off or all separate switches , reinstate rcd, switch on one by one, rcd trips on faulty appliance.... fault found. To be honest customers or non electrical people struggle to reinstate an rcd under fault conditions anyway regardless of the position of the sockets. The key bit is that these sockets are preferably double pole switched indirectly or unplugged directly to find a problem, with an understanding of very basic fault finding knowledge.
until appliance manufacturers make allowances for a socket outlet & plug behind their stupid appliances, this debate will go on for years. it's not rocket science. appliance needs electricity to work. this is usually supplied by a socket outlet. that's why they fit plugs on their appliances. one day they might realise that these plugs what they fit are not just for decoration. they need to be plugged in to a suitable socket within reach of their ridiculously short leads.
A little far away
I have no preferred method, every kitchen is different.
From Pull Up Sockets in the worktop, to pull down sockets hidden in the wall units. Isolators in a Larder unit for appliances to some grid switching, or a sub DB for appliances. Also have the likes of a bank of switches contolling contactors, but that can get expensive.
Thanks for adding
What's your preferred method anyway?
The only person who would ever think that having an isolation switch in plain view as a preferred option is an electrician or geek. And don't get me onto grid switches. In the last 10 years in my kitchen I have never had to turn off an appliance quickly, and if I had, I could have isolated it by either using the plug in the cupboard next to the appliance or using the functional switch for the circuit in my consumer unit. All appliances are fed from switched single socket outlets in the adjacent cupboard and I always fit kitchens this way. Modern appliances are generally low power consumption so don't sweat the small stuff, put it all on a kitchen rfc, get those switches hidden away, forget about them and move on.:)
Cooker switch... on show or hidden away like your skts in adjacent cupboards?? Like your passion and straight the point answer
If your not an electrician or a geek.... what are you then?
I tell 'em...want your washing machine or tumble drier plugged in to a socket behind? With a sfcu above the worktop? Specify a 700mm worktop then. Simple. Oh, that'll be expensive! Yes, and a nightmare for the poor tester in a rented house who has to lug them appliances out anyway...
Socket in adjacent cupboard, or extension lead in kickspace...come on, how often is that a problem?
Accessibility is the key, IMHO.
Yes...I know...but hear what others say on here too. Only time I need a cooker switch is when i change the cooker...
The use of an extension lead is not a problem for fixed, sorry, stationary appliances. The testing regulations, sorry, recommendations state that extension leads should be tested according to their usage. Those used in general, multiple usage are obvioulsy more likely to suffer damage, those serving a large, stationary appliance are not.
Case in point...large "American Fridge freezer"...plugged into a single socket at skirting level behind. It's full of food, weighs about half a ton...you need to isolate it? Pull it out? No, you go to the top of the unit and unplug it from the extension lead that has been looped up from the socket to the top of the unit...that way it can be tested. Yes, the FVI is compromised but let's be fair, it hasn't moved for 5 years, so only rodent chewing could have caused a problem...and if it tests ok, it probably is ok. Plus, if you really do want to pull it out, the length of the extension allows that...so, not a total bodge, in my view...not perfect either, but perfection is more difficult to obtain. It is possible, and I have done it, but for the vast majority of normal folks it isn't achievable. So, similarly, with washing machines and tumble driers, bring their cables into the dead space next door...ie into the adjacent cupboard, or the kickspace, and they are readily accessible. I fully accept that there are some minor risks, but I also suggest that these are minuscule compared with dragging appliances out for testing then shoving them back in, hoping that the compression/crushing of the flexes doesn't compromise the electrical safety. I'd far rather be able to check the connections in plain view than have to rely on hope that all is well behind the scene.
everything in a kitchen is supposed to be functional, not decorative. it's a room for preparing and cooking food, not some shiny showroom to show off to the neighbours. next thing is we''ll be wanting to hide the hob under some smoked glass cover so it's not seen.
This kitchen argument drives me mad!
What's the first priority of the regs - Safety?
What's (or should be) the first priority of an electrician - Safety?
What's the most common source of 'fire causing' failure - Connections.
So why bury a plug and socket well out of sight, behind a machine or in a cupboard full of flammable material? - I know - cos it's pretty!
That's what matters most, isn't it?
Rolyberkin : when your oven starts crackling and smoking, your customer needs to switch it off - quick!
I think DP switches above a machine are best, with sufficient flex to allow m/c withdrawal - but don't go adding a socket outlet behind - that defeats the whole purpose ( it can also get wet!).
I do hope the 18th brings some common sense to this, even if it just means you can say " sorry missus, that's the new regs"
...What's the most common source of 'fire causing' failure - Connections.
I think DP switches above a machine are best, with sufficient flex to allow m/c withdrawal - but don't go adding a socket outlet behind - that defeats the whole purpose...
So where and how would you make the connection between the fixed wiring and a washing machine flex?
Reply to Kitchen Socket Circuits?? in the UK Electrical Forum area at ElectriciansForums.net
