Discuss Kitchen Socket Circuits?? in the UK Electrical Forum area at ElectriciansForums.net
I tell 'em...want your washing machine or tumble drier plugged in to a socket behind? With a sfcu above the worktop? Specify a 700mm worktop then. Simple. Oh, that'll be expensive! Yes, and a nightmare for the poor tester in a rented house who has to lug them appliances out anyway...
Socket in adjacent cupboard, or extension lead in kickspace...come on, how often is that a problem?
Accessibility is the key, IMHO.
Yes...I know...but hear what others say on here too. Only time I need a cooker switch is when i change the cooker...
The use of an extension lead is not a problem for fixed, sorry, stationary appliances. The testing regulations, sorry, recommendations state that extension leads should be tested according to their usage. Those used in general, multiple usage are obvioulsy more likely to suffer damage, those serving a large, stationary appliance are not.
Case in point...large "American Fridge freezer"...plugged into a single socket at skirting level behind. It's full of food, weighs about half a ton...you need to isolate it? Pull it out? No, you go to the top of the unit and unplug it from the extension lead that has been looped up from the socket to the top of the unit...that way it can be tested. Yes, the FVI is compromised but let's be fair, it hasn't moved for 5 years, so only rodent chewing could have caused a problem...and if it tests ok, it probably is ok. Plus, if you really do want to pull it out, the length of the extension allows that...so, not a total bodge, in my view...not perfect either, but perfection is more difficult to obtain. It is possible, and I have done it, but for the vast majority of normal folks it isn't achievable. So, similarly, with washing machines and tumble driers, bring their cables into the dead space next door...ie into the adjacent cupboard, or the kickspace, and they are readily accessible. I fully accept that there are some minor risks, but I also suggest that these are minuscule compared with dragging appliances out for testing then shoving them back in, hoping that the compression/crushing of the flexes doesn't compromise the electrical safety. I'd far rather be able to check the connections in plain view than have to rely on hope that all is well behind the scene.
everything in a kitchen is supposed to be functional, not decorative. it's a room for preparing and cooking food, not some shiny showroom to show off to the neighbours. next thing is we''ll be wanting to hide the hob under some smoked glass cover so it's not seen.
Oven, Hob or microwave accessible above the counter for "emergency switching" , the rest, hide them away out of sight.
can't do that. all cupboards are full of the screaming kids, hidden away out of sight.
This kitchen argument drives me mad!
What's the first priority of the regs - Safety?
What's (or should be) the first priority of an electrician - Safety?
What's the most common source of 'fire causing' failure - Connections.
So why bury a plug and socket well out of sight, behind a machine or in a cupboard full of flammable material? - I know - cos it's pretty!
That's what matters most, isn't it?
Rolyberkin : when your oven starts crackling and smoking, your customer needs to switch it off - quick!
I think DP switches above a machine are best, with sufficient flex to allow m/c withdrawal - but don't go adding a socket outlet behind - that defeats the whole purpose ( it can also get wet!).
I do hope the 18th brings some common sense to this, even if it just means you can say " sorry missus, that's the new regs"
...What's the most common source of 'fire causing' failure - Connections.
I think DP switches above a machine are best, with sufficient flex to allow m/c withdrawal - but don't go adding a socket outlet behind - that defeats the whole purpose...
So where and how would you make the connection between the fixed wiring and a washing machine flex?
Reply to Kitchen Socket Circuits?? in the UK Electrical Forum area at ElectriciansForums.net
Currently planning a new rewire for my kitchen and want to get things right first time when it comes to appliances consumptions and circuits...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
