I'm having an extension built, electrics are going to plan. Socket cables are in (went for new ring in the end), light cables and I decided to add a feed for the shed which comes in on 2.5 anaconda.
My question is should I add a new consumer board using 10mm twin off a space in the existing consumer board. 40a MCB.
Was think of this
British General 8-Module 6-Way Part-Populated Main Switch Consumer Unit | Domestic Consumer Units | NoLinkingToThis - https://www.NoLinkingToThis/p/british-general-8-module-6-way-part-populated-main-switch-consumer-unit/8847j
or take cables back to the existing consumer box which has enough spaces, I've also left all cables long enough for both ways to work.
Terry
Was think of this
Terry
