If they are low load, RCD FCU radial, if not RCD metal clad sockets. Or is there a reason you've discounted these options?
cost would be as much, if not more, than fitting a Memshield 2 RCBO (cost around £40) so that's the option I gave him, also because ther are other existing sockets on the circuit, in different locations. Then the whole circuit is protected.
Reactions: pc1966 and GBDamo
These things are not cheap new, second hand yes but I would opt for new. This is the cheapest I have seen from a quick scan plus you get forum member discount if signed up.
They are expensive, that's almost the same price as the fully loaded 10way dual RCD Hager consumer unit sold on the same website!
  • Funny
Reactions: DPG and westward10
John, you absolute mad man. ?
[automerge]1599937805[/automerge]
Good price that. I had a nightmare with these once. Tested a Memshield 2 board and needed to add some RCD protection to 4 or 5 circuits. Went to fit the pods and they were blood the Memera MCBs that these don’t fit onto. Lesson learned that day to always check the type of breakers fitted into MEM S2 boards. Look exactly the same just say Memera on them.
As this thread has gone off topic somewhat (amongst other reasons which should soon become self-evident).... CLOSED :D
  • Funny
Reactions: HappyHippyDad
nuisence tripping rcd
kanewesley,
SparkyChick,
