Currently reading:
How can i start a different pump at each start ?
Discuss How can i start a different pump at each start ? in the Commercial Electrical Advice area at ElectriciansForums.net
So I have 2 pumps, when i turn a selector on i want to start the first pump.
Once the selector was turned off and on again, I want to start the second pump.
And any time i repeat it i have to turn on the other pump which was not running on the previous startup.
How can i do this whitout a PLC ?
Smart relays are easy enough with drag and drop logic/function blocks and cheap. Basically a mechanical mini PLC.
What’s wrong with 2 interlocked switches?
Thank you for your response.
Could you give me an exemple for a smart relay which can do that?
Because basically I also thought that, but I could not find relays like that 🥺
Reply to How can i start a different pump at each start ? in the Commercial Electrical Advice area at ElectriciansForums.net
